A Simple Crystallography Question
by ian_K_Robinson
Tags: crystallography, simple
ian_K_Robinson
ian_K_Robinson is offline
#1
Dec30-13, 03:40 AM
P: 1
Hi
could anyone help with a simple crystallography question.
I am studying domain growth in crystals via Monte-Carlo simulations of atomistic models. I am writing a program to simulate the (neutron ) scattering pattern from a data-file of atomic positions via the rather brute force method of summing the scattered wave intensities at each point on a detector.
If I want to generate a pattern from a particular orientation say 4,2,0 planes. Should the incident beam be perpendicular to the desired plane with the detector at some distance perpendicular to the incident ray or should the beam be at some arbitrary angle such as 1,1,0 with the detector oriented at 4,2,0 ?
Any suggestions very gratefully received
Ian Robinson
an ancient Ph.D candidate
Phys.Org News Partner Physics news on Phys.org
Vacuum ultraviolet lamp of the future created in Japan
Understanding the energy and charge transfer of ions passing through membranes
High-temperature plasmonics eyed for solar, computer innovation
M Quack
M Quack is offline
#2
Jan3-14, 01:49 AM
P: 640
The incident and diffracted beam should form the Bragg angle with the 4,2,0 planes. There is a remaining degree of freedom, rotation within the planes, that is referred to as "azimuth". For your calculations that should not matter.
This is a very common technique used in x-ray diffraction known as diffraction topography or diffraction tomography.
If you want to see how the domain distribution affects the peak shape, then you also have to calculate the diffracted intensity for angles slightly smaller or larger than the nominal Bragg angle.
Register to reply
Related Discussions
Bragg's Law in Crystallography Biology 3
Braggs law and x-ray crystallography Quantum Physics 4
Polarization and crystallography General Physics 6
crystallography question Advanced Physics Homework 1
crystallography concept help Classical Physics 15
