Register to reply
Water and pressure
by dhulke
Tags: boiling point, pressure, water
Share this thread:
dhulke
#1
Jan1-14, 04:21 PM
P: 1
Hi!
So I'm pretty confused about the effects that pressure has on water. If I increase pressure, I increase the boiling point. Likewise, if I increase pressure I increase temperature. How's that?
That's the way air-conditioning works, by increasing pressure on one side and decreasing pressure on the other this way one side gets hotter and the other gets colder. But if by increasing pressure, temperature increases, shouldn't my deodorant bottle be hot?
And if I have water and I apply pressure, shouldn't it turn to ice at some point? I'm so confused... Can anybody help me?
Phys.Org News Partner Chemistry news on Phys.org
Scientists develop 'electronic nose' for rapid detection of C. diff infection
A new synthetic amino acid for an emerging class of drugs
Team pioneers strategy for creating new materials
SteamKing
#2
Jan1-14, 06:09 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,547
You are confused about how air conditioning works. See this article (vapor compression cycle):
http://en.wikipedia.org/wiki/Refrige...pression_cycle
A liquid boils when its vapor pressure equals or exceeds the ambient pressure acting on the free surface. Water boils at 100 C at sea level when the atmospheric pressure is 1 atmosphere. If you go to the top of a tall mountain, where the atmospheric pressure is less than 1 atmosphere, the boiling point of water is reduced below 100 C.
russ_watters
#3
Jan1-14, 11:18 PM
Mentor
P: 22,301
Welcome to PF!
Quote Quote by dhulke View Post
Anything that is hot can be made cold again: the effect isn't permanent. If it was, air conditioning wouldn't work. So with air conditioning, it goes like this:
1. The gas is compressed and gets hot.
2. The gas is run through a heat exchanger to cool it (and some liquefies).
3. The gas is allowed to expand, cooling it.
You'd expect that, yes, but ice has a crystal structure that makes it less dense than water. So it isn't that easy.
Register to reply
Related Discussions
Salt water steam pressure vs fresh water steam pressure Engineering, Comp Sci, & Technology Homework 5
Calculating water pressure, gauge pressure Introductory Physics Homework 3
Velocity of a water jet given water pressure and diameter? Advanced Physics Homework 3
Oil spill: Water pressure VS. oil pressure Classical Physics 30
Water Pressure Calculation with atmospheric pressure corrections General Physics 7
