Register to reply
Gravity and light
by louisrancourt
Tags: gravity, light
Share this thread:
louisrancourt
#1
Jan2-14, 09:33 AM
P: 3
hi
Can you explain why a mobile mass is pushed towards a hidden light and goes back to original position when light is turned off. The mobile mass is at the end of a torsional pendulum suspended by trifilar small copper wire and is completely enclosed in a box. No air movement perceived.
Louis
Phys.Org News Partner Physics news on Phys.org
Engineers develop new sensor to detect tiny individual nanoparticles
Tiny particles have big potential in debate over nuclear proliferation
Ray tracing and beyond
ZapperZ
#2
Jan2-14, 09:38 AM
Emeritus
Sci Advisor
PF Gold
ZapperZ's Avatar
P: 29,238
Quote Quote by louisrancourt View Post
hi
Louis
This description is vague and confusing. Please provide proper, published citation where this experiment has been published, per the requirement of our PF Rules.
Zz.
louisrancourt
#3
Jan2-14, 09:45 AM
P: 3
hi
The paper :The effect of light on gravitational attraction ' was puiblished in Physics essays, december 2011. More experiment for 3 years led to the same conclusion. It really seems that there was a pushing force on the mass. Maybe its time to revise our notion of gravitational forces and their nature.
Louis
ZapperZ
#4
Jan2-14, 09:57 AM
Emeritus
Sci Advisor
PF Gold
ZapperZ's Avatar
P: 29,238
Gravity and light
hi
Louis
1. This is a dubious journal.
2. You obviously have no clue on how to provide a proper scientific citation. Please use Author, Journal name, volume number, page number, year.
3. Have you tried to do a citation index on the paper and see how many references were made to it and whether this has been verified and explained?
Zz.
Malverin
#5
Jan2-14, 10:19 AM
P: 134
Maybe he speaks about something like this
http://en.wikipedia.org/wiki/Optical_tweezers
But that is interesting too
http://www.technologyreview.com/news...-repels-light/
ZapperZ
#6
Jan2-14, 11:35 AM
Emeritus
Sci Advisor
PF Gold
ZapperZ's Avatar
P: 29,238
Sorry, but what you cite sounds nothing like what the OP described. Those experiments do not require us to "... revise our notion of gravitational forces... " Please wait for the OP to clarify.
Zz.
louisrancourt
#7
Jan2-14, 04:50 PM
P: 3
hi
I realized there was not enough details to explain what happened in the experiment.
A 50 cm torsion pendulum supported in its middle point by 3 fine copper wire is placed in a cubicle. 100 g mass are placed at each end of the pendulum. A 500 g mass is brought close to one end of the pendulum and a point is reached where the gravitational attraction of the 500 g mass is balanced by the restoring force of the torsion wires. When that equilibrium point is reached, a 30 degrees laminar red laser beam is passed between the 2 masses, without touching them. The mobile mass slowly gets closer to the 500 g mass. When the light is cut off, the mobile mass returns to its equilibrium point. There was no measurable increase of temperature, no air movement and no static electric field detected.
The effect begins right away and stops when the light is cut off. When the laser beam was directed on the opposite side of the 100 g mass, it moved again towards the light beam.
What physical process can explain these facts?
Any help will be appreciated.
Louis
Drakkith
#8
Jan2-14, 05:02 PM
Mentor
Drakkith's Avatar
P: 11,904
What's the problem? Light has energy and thus affects spacetime the same way mass does, generating gravity.
Vanadium 50
#9
Jan2-14, 05:30 PM
Mentor
Vanadium 50's Avatar
P: 16,386
If you have 100g and 500 g masses and are watching them move, whatever you are looking at, it's not gravity.
bahamagreen
#10
Jan2-14, 07:04 PM
P: 544
Until this experiment is performed in vacuum in free fall, how does one not eliminate any possible Bernoulli / Venturi effects - that the laser might be causing the air to flow... or that heating of the air is causing an "up draft" of the air in the gravitational field?
Or that the masses are responding to the change in position of the experimenter as he moves around the apparatus to switch the laser on and off...?
Vanadium 50
#11
Jan2-14, 08:22 PM
Mentor
P: 16,386
Again, it doesn't matter if it's air drafts or not. The central premise - that this is a measurement of gravity - is simply wrong.
ZapperZ
#12
Jan2-14, 09:25 PM
Emeritus
Sci Advisor
PF Gold
ZapperZ's Avatar
P: 29,238
hi
Louis
You still have not provided the proper citation, and thus, all we have to go by is your interpretation of the experiment. Sorry, but that isn't enough.
I'm an experimentalist. The DETAILS of the experiment, of ANY experiment, are vital, based on my experience of not only performing such experiments, but also in refereeing any manuscript submitted for publication. Your description alone is not sufficient.
So unless you are able to provide the proper citation, then this topic does not meet the criteria for the source of discussion that we have outlined in the PF Rules that you had agreed to. It will result in this thread being closed.
Zz.
Register to reply
Related Discussions
Gravity Deflecting Light and Gravity Lensing Special & General Relativity 1
GR - Gravity versus light - acceleration of light? Special & General Relativity 2
The gravity of light Special & General Relativity 5
Gravity? and light? General Physics 5
Gravity faster light?/new ideas light! General Physics 2
