Register to reply
Fresnel lens project with my dad
by MACHO-WIMP
Tags: cracked, fresnel, fresnel lens, lens, project
Share this thread:
MACHO-WIMP
#1
Jan3-14, 12:26 PM
P: 43
Hello,
So my dad and I took apart our old TV that had a Fresnel lens inside. Unfortunately there is a crack near the edge due to a billiard ball accidentally being dropped on it. I was wondering how much this crack would affect the lens' ability to focus the sunlight into a point. When we tested this, it didn't work as well as it did in the video, and had trouble burning dead leaves but we think that since it is winter here in the Northern Hemisphere that might have something to do with it. Any comments or advice would be very helpful. Thanks!
PS: we were inspired by this video:
http://www.youtube.com/watch?v=jrje73EyKag
Phys.Org News Partner Physics news on Phys.org
Physicists discuss quantum pigeonhole principle
First in-situ images of void collapse in explosives
The first supercomputer simulations of 'spin?orbit' forces between neutrons and protons in an atomic nucleus
etudiant
#2
Jan3-14, 08:06 PM
PF Gold
P: 858
Just one crack should not have much effect at all on the lens's functionality.
Your description suggests that this lens was not designed to focus light to a point, so it would not be that good at burning leaves. Still, summer noonday sun should improve the performance somewhat.
Redbelly98
#3
Jan4-14, 08:22 AM
Mentor
Redbelly98's Avatar
P: 12,071
Also, no lens has the ability "to focus the sunlight into a point", mainly because the sun is not a point source to begin with. The best you can do is focus the sun onto a small area, as determined by the focal length of the lens.
MACHO-WIMP
#4
Jan4-14, 01:19 PM
P: 43
Alright thanks you guys! Helped a lot.
davenn
#5
Jan4-14, 04:05 PM
Sci Advisor
PF Gold
davenn's Avatar
P: 2,484
A fresnel lens from a TV/Monitor is used to diffuse light ( spread it out) NOT concentrate light
Dave
sophiecentaur
#6
Jan5-14, 10:58 AM
Sci Advisor
PF Gold
sophiecentaur's Avatar
P: 11,919
Quote Quote by davenn View Post
Dave
Where would you find a fresnel lens in a TV? They are common enough in old fashioned OHPs but, as for a TV - are we talking about the lens they used to put in front of 9" tubes to make them look line 12" tubes? That would be a convex (Magnifying) lens, which should focus the Sun OK. It would probably have a focal length of 0.5m (<=2 dioptres) or so, I'd imagine. It couldn't be much shorter than that or the field of view would be too small for more than one person to watch TV.
(Apologies for trying to tell my astronomer grandma how to suck optical eggs!!)
OmCheeto
#7
Jan5-14, 12:44 PM
PF Gold
OmCheeto's Avatar
P: 1,420
Quote Quote by sophiecentaur View Post
Found it!
I've never seen the insides of one of these:
At the end of the video, you see him also pull out a fairly large mirror.
I'm guessing that there is some kind of miniature TV inside that the mirror and fresnel lens focus on.
More here if you are interested: Rear-projection television
In regards to the OP's video, what he did with that gasoline was incredibly stupid. Do not try anything like that, or you may end up without a recognizable face.
davenn
#8
Jan5-14, 02:38 PM
Sci Advisor
PF Gold
davenn's Avatar
P: 2,484
There's one inside every TV/ monitor that uses backlighting ... so normally LCD type
it sits behind the LCD panel and it diffuses the light from the back lights to give an even lighting across the whole screen
the backlight is usually either fluoro tubes or LEDs
don't think they are used in Plasma screens .... never pulled one apart to find out
thanks Om
yes they were also used in the rear projection TVs as your video showed
I forgot about those ones and was mainly thinking of the other use
cheers
Dave
sophiecentaur
#9
Jan5-14, 06:09 PM
Sci Advisor
PF Gold
P: 11,919
Ah yes; my memory deliberately edited out the rear projection generation TVs (they were so ghastly). I'm not sure about the optics but it could be a way to achieve a long focal length and big aperture in a short space (a la telephoto lens).
In the YouTube movie, the lens seems to be a little under 1 Diopter and the focussing is not too fussy. He is working in full, bright sunlight, of course.
In the LCD backlight system, I always thought it was just a lenticular screen but I didn't think about it in depth. The backlight was a number of strip lights so any lens would be cylindrical.
Register to reply
Related Discussions
How tho choose a fresnel lens General Physics 1
Fresnel lens General Physics 9
Fresnel lens General Physics 1
Need help focusing IR using a fresnel lens Engineering Systems & Design 4
Fresnel lens possibility Engineering Systems & Design 11
