Register to reply
Is Euclid's Fourth Postulate Redundant?
by lugita15
Tags: euclid, postulate, redundant
Share this thread:
lugita15
#1
Jan3-14, 07:55 PM
P: 1,583
Euclid's Elements start with five Postulates, including the fifth one, the famous Parallel Postulate. Less well known, however, is the Postulate that forms the basis for the fifth: the fourth one, which states that "all right angles are equal." Students who see this for the first time might find this puzzling, because obviously two angles which are equal to a 90 degree angle are equal to each other, since Common Notion 1 says that "things which are equal to the same thing are are also equal to one another". But then they realize that the matter is so straightforward: the definition of a right angle is an angle produced when two lines intersect each other and produce equal adjacent angles, and it's not clear why an angle produced by one such pair of lines should bear any relation to an angle produced by another such pair of lines.
So Euclid's fourth Postulate is not redundant for the reason that beginning students might think. But my question is, is it nevertheless a redundant postulate, although for far less trivial reasons? David Hilbert, in his Foundations of Geometry (Grundlagen der Geometrie in German), claims to prove Euclid's fourth Postulate in theorem 15 (on page 19 of the PDF or page 13 according to the book's internal page numbering), prefacing the proof by saying "it is possible to deduce the following simple theorem, which Euclid held - although it seems to me wrongly - to be an axiom."
Now it's fair to say that Hilbert was working in a different (and more rigorous) system of axioms than Euclid was, but I think Hilbert's proof should be seriously considered for two reasons. First of all, why would he dub Euclid's decision to call "all right angles are equal" a Postulate as "wrong" if it merely reflected a stylistic difference concerning what you choose as starting assumptions and what you consider theorems? But more importantly, by tracing back all the assumptions used in the proof of theorem 15, it seems to me that only four of Hilbert's axioms are ultimately used: IV 3, IV 4, IV 5, and IV 6. And I don't think Euclid would have objected to any of these statements:
1. IV 3 follows directly from Euclid's Common Notion 2.
2. IV 4 is partly stated in Euclid's Book I Proposition 23, which doesn't depend on the fourth postulate, and the part of IV 4 which (I think) is not stated is easily provable in Euclid's system.
3. IV 5 follows from Euclid's Common Notion 1.
4. IV 6 is just part of Euclid's Book I Proposition 4, which doesn't depend on the fourth postulate at all.
So could Euclid have proven his fourth Postulate as a theorem instead of just assuming it?
Any help would be greatly appreciated.
Thank You in Advance.
Phys.Org News Partner Mathematics news on Phys.org
Heat distributions help researchers to understand curved space
Professor quantifies how 'one thing leads to another'
Team announces construction of a formal computer-verified proof of the Kepler conjecture
Simon Bridge
#2
Jan3-14, 11:04 PM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 12,961
I think you need to show that the fourth postulate follows from the other four alone to consider that it is redundant to Euclid.
lugita15
#3
Jan3-14, 11:22 PM
P: 1,583
Quote Quote by Simon Bridge View Post
Well, I showed that all of Hilbert's assumptions in the proof were either assumed or proven by Euclid independent of the fourth postulate, so what more is needed?
Simon Bridge
#4
Jan4-14, 01:14 AM
Homework
Sci Advisor
HW Helper
Thanks
P: 12,961
I'm not so sure that you did - you certainly asserted that this was the case.
You should be able to work it backwards so that you can start from Euclid to get his fourth without assuming it.
It should be straight forward enough to show step-by-step, and provides a way to confirm what you've done.
Which is what you need - or did I misunderstand your question?
Register to reply
Related Discussions
Euclid's sixth postulate General Math 4
Finding the converse of Euclid's fifth postulate (parallel postulate) Calculus & Beyond Homework 2
Is Euclid's Postulate 5 really a postulate of parallels ? Differential Geometry 18
Euclid's 5th postulate General Math 1
God is redundant. A Theory General Discussion 99
