Register to reply
Electromagnet directly connected to power supply not working
Share this thread:
QwertyXP
#1
Jan3-14, 10:03 PM
P: 63
Recently, I made an electromagnet by winding copper wire (length: 4m) around a metal screw. The power supply was from a mobile phone charger (5V).
Here's the issue:
When I connected the electromagnet in series with a 10 ohms resistor, it worked fine (attracted nearby metal objects), but when I connected it directly across the 5V supply, it ceased to function! Just to test the connecttions, I connected an LED in series and it also glowed; however, after removing the LED and then again directly connecting the winding with the power supply, the electromagnet didn't work (tried this a few times).
- What could the reason be?
- The energy of an inductor 0.5*LI^2, so increasing the current should have actually made the magnet stronger!?
Phys.Org News Partner Engineering news on Phys.org
DIY glove-based tutor indicates muscle-memory potential
Tricorder XPRIZE: 10 teams advance in global competition to develop consumer-focused diagnostic device
Study shows local seismic isolation and damping methods provide optimal protection for essential computing equipment
Simon Bridge
#2
Jan3-14, 10:55 PM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 12,962
It's broken ... if you return to the original setup (series with 10Ohm resister) does it start attracting stuff again?
cjl
#3
Jan3-14, 11:05 PM
P: 1,018
I'm guessing that your power supply has short circuit protection, and your coil of wire had a low enough resistance to trigger it.
Simon Bridge
#4
Jan4-14, 01:07 AM
Homework
Sci Advisor
HW Helper
Thanks
P: 12,962
either that or the coil was damaged by the large currents - or both.
QwertyXP
#5
Jan4-14, 08:36 AM
P: 63
It worked again after I re-connected it with the 100 ohms resistor. Did this several times.
My power supply was a 5V Nokia mobile phone charger. Do mobile phone chargers usually have overload/short-circuit protection?
AlephZero
#6
Jan4-14, 01:13 PM
Engineering
Sci Advisor
HW Helper
Thanks
P: 7,175
Quote Quote by QwertyXP View Post
Yes, to stop them self-destructing, and/or catching fire, when people abuse them.
Windadct
#7
Jan6-14, 08:37 AM
P: 564
If you measure the resistance of the EM Coil you should be able to calculate the current for the 5V supply and see if it exceeds the supply's ratings. If you do not have a meter - you can look up the wire's resistance per unit length - and calculate the resistance. -- in fact you could/should do both and compare the calculated with the measured results. Lastly - with a voltmeter - measure the voltage from the supply as you connect the EM Coil - does it go to Zero V?
Redbelly98
#8
Jan6-14, 06:36 PM
Mentor
Redbelly98's Avatar
P: 12,071
When I connected the electromagnet in series with a 10 ohms resistor, it worked fine...
It worked again after I re-connected it with the 100 ohms resistor....
Was it 10 or 100 ohms?
Either way, you might try reducing the resistor to get more current, if you can. Just make sure the resistor's power rating is sufficient if you do this.
RocketSci5KN
#9
Jan8-14, 08:04 PM
P: 163
Check the amp rating (I) on the charger (likely 1A or 2A). At 5V output, the resistance R it could handle is 5/I (remember V=I*R ? ). Your wire must have a resistance R the same or greater than this. Your R will be r per foot * (length in feet). Ignore the inductance for this. Make sure the wire you use is insulated, otherwise you will short it out to itself when winding it and it will fail. Magnet wire is best, as it has very thin insulation, but normal wire will also work.
Register to reply
Related Discussions
Current through an inductor connected directly to a battery Introductory Physics Homework 4
Capacitor directly connected to a DC battery. Introductory Physics Homework 3
Power supply for electromagnet Electrical Engineering 9
Peltier Cooler connected to Power Supply, is this configuration safe? Electrical Engineering 2
Connected the capacitor to a DC power supply Electrical Engineering 4
