What is the beat frequence in Hz of ultrasound
  • Thread starter Thread starter confused1
    Ultrasound
The beat frequency of ultrasound reflected from a bloodstream moving at 30 cm/s with an original frequency of 2.5 MHz is calculated to be 487.8 Hz. This calculation utilizes the Doppler effect to determine the frequency of the reflected wave, considering the velocity of sound in blood at 1540 m/s. The wavelength is derived from the original frequency, leading to the final beat frequency calculation using the formula: beat frequency (Hz) = | velocity of sound (m/s) | / wavelength (m).
  • Doppler effect principles
  • Ultrasound frequency calculations
  • Unit conversion (cm/s to m/s)
  • Wavelength determination using frequency and velocity
  • Learn about the Doppler effect in medical ultrasound applications
  • Explore advanced ultrasound imaging techniques
  • Study the impact of blood flow velocity on ultrasound diagnostics
  • Investigate the relationship between frequency and wavelength in wave physics
Medical professionals, ultrasound technicians, and physics students interested in the application of the Doppler effect in medical imaging and diagnostics.
confused1
Ultrasound reflected from an oncoming bloodstream that is moving at a 30 cm/s is mixed with the original frequency of 2.5 MHz to produce beats. What is the beat frequency in Hz? (Velocity of sound in blood = 1540 m/s.)
Find the frequency of the reflected wave using the "doppler effect" equation. Remember that the bloodstream is moving towards the observer.
Then use the beat equation with the two frequencies (2.5MHz and what you get above using doppler).
Careful with your units.
The beat frequency in Hz can be calculated using the formula:
First, we need to convert the velocity of the bloodstream from cm/s to m/s:
30 cm/s = 0.3 m/s
Next, we can calculate the wavelength using the formula:
wavelength (m) = velocity of sound (m/s) / frequency (Hz)
Since we know the velocity of sound in blood is 1540 m/s and the frequency is 2.5 MHz, we can solve for the wavelength:
wavelength (m) = 1540 m/s / 2.5 MHz
= 0.000616 m
Now, we can plug in the values into the formula for beat frequency:
beat frequency (Hz) = | 0.3 m/s | / 0.000616 m
= 487.8 Hz
Therefore, the beat frequency in Hz of ultrasound reflected from an oncoming bloodstream moving at 30 cm/s with an original frequency of 2.5 MHz is 487.8 Hz.
  • · Replies 23 ·
