Register to reply
Force at point A and E (Static Equilibrium)
by abcnat
Tags: equilibrium, force, point, static
Share this thread:
abcnat
#1
Jan3-14, 10:43 PM
P: 4
a man is trying to fix the light bulb at the top of his house ceiling.to reach the bulb,he is using a stepladder that is in equilibrium state.sides AC and CE are each 9.0 m long and hinged at C.Bar BD is attached with a rod that is 3.0 m long,halfway up.The man who is climbing 5.0 m along the ladder (AC) is 67 kg in weight.Assume that the floor is frictionless and the mass of the ladder is negligible.
Find the forces at points A and E.
Phys.Org News Partner Engineering news on Phys.org
Researchers discover cool-burning flames in space, could lead to better engines on earth (w/ Video)
Professors object to FAA restrictions on drone use
UConn makes 3-D copies of antique instrument parts
Simon Bridge
#2
Jan3-14, 10:54 PM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 12,463
Welcome to PF;
Good question - I take it this is an A-frame ladder?
What have you tried so far?
abcnat
#3
Jan3-14, 11:08 PM
P: 4
yes with bar in the middle. I get 1220.38 N at point A and 928.58 N at point E.I also tried other calculation which i get 129.6 N at point A
Simon Bridge
#4
Jan4-14, 01:08 AM
Homework
Sci Advisor
HW Helper
Thanks
P: 12,463
That's neet - so which one is right?
I cannot tell unless you show me your working + your reasoning.
abcnat
#5
Jan4-14, 01:16 AM
P: 4
first draw free body diagram and find angle and stuff so
at point A
9(Fna sin 19.47)=4(mg cos 70.53) + 4.5(Fb cos 19.47)
9(Fna sin 19.47)=875.4 N + 2785.74 N
Fna=1220.38 N
but I'm not sure.the other calculation is pretty much the same but with different angle and get 129.6 N
so what did you get at point A?
overall i did 3 calculations all with different answers.please help me
Simon Bridge
#6
Jan4-14, 07:05 PM
Homework
Sci Advisor
HW Helper
Thanks
P: 12,463
Is Fna is the magnitude of the force at point A, normal to side AC
Is Fb the total force at point B?
What happened to the force at point C?
Which angle is 19.47deg?
... I cannot see your reasoning.
Note: you don't need to calculate any angles to do this problem - and your end result will be more accurate if you don't.
eg. lets call the angle ∠ACE is β, then cos(β)=1/3, sin(β)=(√2)/3
Each time you need a cosine of that angle, just write in 1/3.
Register to reply
Related Discussions
Static equilibrium for three point charges Introductory Physics Homework 1
Which direction do we assume the static friction force to be in? (Static equilibrium) Classical Physics 1
Static equilibrium & force of friction Introductory Physics Homework 11
Static equilibrium: calculating force of tension Introductory Physics Homework 7
Point charges and static equilibrium Introductory Physics Homework 4
