Analyzing a Multi-storey multi-bay frame subjected to lateral load
by median27
Tags: analyzing, frame, lateral, load, multibay, multistorey, subjected
median27
median27 is offline
#1
Jan5-14, 07:08 AM
P: 60
What is the best/easiest method I can use to get the deflections of a 5-storey, 3-bay frame subjected to lateral loads only? I've used the Elemental stiffness matrix for two-dimensional frame analysis (giving me a 60 x 60 matrix) but I'm getting the wrong deflection values. I think my procedure is erroneous because I've only referred to a single storey, single bay frame example in the book. Any help would be appreciated. Thanks.
Phys.Org News Partner Engineering news on Phys.org
Lifting the brakes on fuel efficiency
PsiKick's batteryless sensors poised for coming 'Internet of things'
Researcher launches successful tech start-up to help the blind
AlephZero
AlephZero is online now
#2
Jan5-14, 10:46 AM
Engineering
Sci Advisor
HW Helper
Thanks
P: 6,351
The method you used is OK, so you must have made a mistake somewhere.
The "easiest" way is use a finite element analysis computer program instead of setting setting up the stiffness matrix yourself - but if the objective is to learn how the FE method works, not to design a building, then you do need to work through the details yourself.
nvn
nvn is offline
#3
Jan5-14, 01:14 PM
Sci Advisor
HW Helper
P: 2,110
median27: I am not sure what the "Elemental stiffness matrix for two-dimensional frame analysis" method is, unless it is just the finite element method. The best and easiest method is the finite element method. Are all of your connections moment connections? Are all of your applied loads nodal applied loads, not uniformly-distributed loads? Do you have a finite element analysis software program? Is this a school assignment, or test question?
Register to reply
Related Discussions
Local strain energy density for a plate subjected to in-plane linear load Mechanical Engineering 1
Why does the beam's deflection diagram smile when subjected to load? Mechanical Engineering 4
What is the formula for bending moment of a beam subjected to UDL and a point load? Engineering, Comp Sci, & Technology Homework 11
Load combo's on footing subjected to large wind loads General Engineering 1
Calculating the load rating for a multi-bar hinge? General Engineering 1
