Register to reply
Gas in light bulb
by MathewsMD
Tags: bulb, light
Share this thread:
MathewsMD
#1
Jan8-14, 05:09 PM
P: 295
If you have a light bulb that weighs 10 g when empty, how does adding an ideal gas inside of it change the mass?
If I'm not mistaken, the force the gas exerts on the light bulb (well, a perfectly symmetrical object is a better example) is the pressure, and it would be pointing in all directions. Overall, all the upward and downward vectors (as well as others) of the force of the individual gas molecules would cancel, right? So then, how exactly would the force of gravity of this system be different from 10 g if the Fup-gas = Fdown-gas, just in opposite directions? Wouldn't this cancel the effects of the light bulb being pushed down since the net force from the gas (the weight from the gas) is 0.
Phys.Org News Partner Chemistry news on Phys.org
Photosensitive version of amiloride allows regulating the function of sodium-specific ion channels with light
Scientist hopes to improve rare earth purification process
Highly efficient nanoparticles could bring down the cost of fuel cells
SteamKing
#2
Jan8-14, 06:19 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,261
A helium filled balloon rises not because the helium pressure vectors inside the envelope cancel, but because the balloon with the helium inside is lighter than the air it displaces.
In a balloon, the pressure of the inflating gas gives the envelope its inflated shape. In a light bulb, which has a glass envelope that is stiffer than that of a balloon, the pressure of the gas inside pushes against the glass, which in turn, pushes back against the gas pressure.
phinds
#3
Jan8-14, 07:06 PM
PF Gold
phinds's Avatar
P: 6,076
Quote Quote by MathewsMD View Post
Do you understand the difference between weight and mass? You seem to be using one to ask about the other.
Borek
#4
Jan9-14, 02:40 AM
Admin
Borek's Avatar
P: 23,363
Gas in light bulb
Forces acting inside of the bulb and forces acting outside of the bulb are not the same forces.
russ_watters
#5
Jan9-14, 05:41 AM
Mentor
P: 22,219
The OP is actually correct on the logic, just wrong on the conclusion: the pressure on the bottom surface of the lamp is higher than on the top surface, due to the weight of the gas.
The problem is just a usually useful simplifying assumption (equal pressure everywhere) that isn't 100% correct and in this case leads you to the wrong answer.
Register to reply
Related Discussions
Intensity of the light in the light bulb what physicist described it? Introductory Physics Homework 5
Would the light bulb light up from the electromagnetic wave? Introductory Physics Homework 5
Light a light bulb with no contact? General Physics 6
Light bulb Introductory Physics Homework 4
Light bulb General Engineering 6
