What is this material?
by etherist
Tags: material
etherist
etherist is offline
#1
Jan9-14, 07:15 AM
P: 14
Is there any materials that is elastically solid (ductile that can be shaped into thin wires) at low temperatures but liquid at room temperatures?
Phys.Org News Partner Engineering news on Phys.org
Lifting the brakes on fuel efficiency
PsiKick's batteryless sensors poised for coming 'Internet of things'
Researcher launches successful tech start-up to help the blind
jedishrfu
jedishrfu is offline
#2
Jan9-14, 08:06 AM
P: 2,477
Mercury maybe depending on how low the temperature.
pikpobedy
pikpobedy is offline
#3
Jan9-14, 02:15 PM
P: 39
woods metal is 70C mp. there are others all a few tens of degrees above room temp
http://en.wikipedia.org/wiki/Wood%27s_metal
As was stated mercury -39C mp
etherist
etherist is offline
#4
Jan10-14, 05:25 AM
P: 14
Is there any material? Metal has a high melting point, it cannot be.
Baluncore
Baluncore is offline
#6
Jan13-14, 01:14 AM
Thanks
P: 1,291
Is the material electrically conductive ?
What colour is it ?
Does it smell ?
Where did you find it ?
What do you want to use it for ?
The metal elemental Gallium melts at a temperature of 29.76 C
etherist
etherist is offline
#7
Jan13-14, 06:01 AM
P: 14
The material necessary be nontoxic.
It must be viscous at liquid states.
I prefer an electrically conductive material and Non-newtonian.
The reason why i wanted a material that is liquid at room temperature but ductile at its solid state is because i wanted to produce a very small pipe filled with that liquid. Is it possible for a wire-material to electroplate it with aluminum or other metal below its melting point? so that when it is heated to room temperature, i have a pipe filled with viscous liquid?
RocketSci5KN
RocketSci5KN is offline
#8
Jan13-14, 01:53 PM
P: 157
Galinstan is a nontoxic alternative for Mercury in thermometers. These are generally not compatible with aluminum, but you'll need to do some research to see what metals they are compatible with. I would not attempt any electroplating - simply get tubes of compatible metals of the correct size and fill. You have limited choices for metals or alloys that are liquid at RT.
Register to reply
Related Discussions
What Material Is This Materials & Chemical Engineering 2
What Is Sub Material? Materials & Chemical Engineering 1
Measurement of material displacement using recorded material thermal data Materials & Chemical Engineering 3
IIT-JEE material Physics Learning Materials 0
Material Science, Material Selection Question Engineering, Comp Sci, & Technology Homework 1
