Can't seem to match the answer help
  • Thread starter Thread starter laker_gurl3
    Match
The concentration of Sr(OH)2 in a solution with a pH of 11 is 5.0 x 10^-4 M. To determine this, first calculate the pOH by subtracting the pH from 14, resulting in a pOH of 3. The concentration of hydroxide ions [OH-] is then found using the formula [OH-] = 10^-pOH, yielding 0.001 M. Since Sr(OH)2 dissociates into two hydroxide ions, the concentration of Sr(OH)2 is half that of [OH-], confirming the correct concentration as 0.0005 M.
  • Understanding of pH and pOH concepts
  • Knowledge of dissociation of strong bases
  • Familiarity with stoichiometric ratios in chemical reactions
  • Ability to perform logarithmic calculations
  • Study the dissociation of strong bases like Sr(OH)2
  • Learn about calculating pH and pOH in various solutions
  • Explore stoichiometry in chemical reactions
  • Review logarithmic functions and their applications in chemistry
Chemistry students, educators, and professionals involved in analytical chemistry or chemical education who need to understand the calculations related to pH, pOH, and the concentrations of strong bases.
laker_gurl3
What is the concentration of Sr(OH)2 in a solution with a pH of 11?
The answer is SUPPOSED to be 5.0 x 10^-4...buuut i keep getting 0.001..
i didnt think this would be a complicated question.. all i did was found the pOH to be 3..and found the concentration of OH, giving me .001
what am i doing wrong?:S
I'm not completely sure (I should be sure though! :P)
Equation is:
Sr(OH)2 + H2O <==> 2OH- + Sr((OH)O <---??
But anyways, the important thing is that there the hydroxide anion has a subscript of 2. You have to pay attention to the stoichiometric rations; therefore the molar ratio of the concentration of Sr(OH)2 to OH is 1:2.
Your 0.001 concentration of OH- present in solution is correct, but then you have to divide it to two to get the concentration of the Sr(OH)2.
[tex]0.001 \div 2 = 0.0005 or 5.0 \times 10^{-4}[/tex]
-Art
It's possible that you may be making a calculation error or using the wrong formula. The correct way to find the concentration of Sr(OH)2 in a solution with a pH of 11 is to first find the pOH, which is 14 - pH, giving you a pOH of 3. Then, use the formula [OH-] = 10^-pOH to find the concentration of hydroxide ions. In this case, [OH-] would be 10^-3 or 0.001. Since Sr(OH)2 dissociates into two hydroxide ions, the concentration of Sr(OH)2 would be half of the concentration of hydroxide ions, which is 0.0005 or 5.0 x 10^-4. Double check your calculations and make sure you are using the correct formula to get the correct answer.
