How do you find the temperature of the boomerang nebula?
by melodyman888
Tags: blackbody, boomerang, nebula, stefan-boltzmann, temperature, temperature and heat, wiens
melodyman888
melodyman888 is offline
#1
Jan18-14, 08:40 PM
P: 2
So i have a physics presentation to do on tuesday and i have no idea how to find the temperature of a of objects in space, specifically the boomeran nebula. I did some research and found stuff involving black body radiation, wiens law, and stefan boltzman law but i dont really understand it too well.
Some of the things i dont understand:
wiens law states that wavelength(in meters) is equal to 0.0029/temperature(K). so is finding the temperature of the boomerang nebula really as easy as simply searching for the wavelength? is there a mathematical way to find the wavelength?
how can something so cold be so bright?
does the black body radiation curve have anything to do with this?
If none of this is the right approach to finding the temperature, how did they do it?
Any help will be greatly appreciated
thanks, melodyman888
Phys.Org News Partner Astronomy news on Phys.org
Unique pair of supermassive black holes in an ordinary galaxy discovered
Red stars and big bulges: How black holes shape galaxies
Image: X-raying the cosmos
davenn
davenn is offline
#2
Jan18-14, 09:24 PM
Sci Advisor
PF Gold
davenn's Avatar
P: 2,243
hi there
welcome to PF
never heard of the boomerang nebula, what is its NGC or IC number ?
it may be a reflection nebula of which a large majority are
BTW DONT post the same question in multiple forum sections
it leads to lots of confusion!
cheers
Dave
Simon Bridge
Simon Bridge is offline
#3
Jan18-14, 11:12 PM
Homework
Sci Advisor
HW Helper
Thanks ∞
PF Gold
Simon Bridge's Avatar
P: 11,070
Basically the color of a hot object depends on it's temperature... so, yes, it is a matter of measuring the wavelengths of the light the gas gives off. The overall spectrum is usually needed though.
The brightness of the light depends on how big the object is, and how far away it is, as well as it's temperature. You'll find the nebula is exremely big.
Drakkith
Drakkith is online now
#4
Jan19-14, 12:11 AM
PF Gold
Drakkith's Avatar
P: 11,055
Note that the Boomerang Nebula is visible because it reflects and scatters light from the central star, not because it is glowing.
Drakkith
#5
Jan19-14, 12:26 AM
PF Gold
Drakkith's Avatar
P: 11,055
As I said in your other thread, the nebula is a reflection nebula, so it's visible because of the light it reflects scatters, not because it emits light. I'm afraid I don't know how they found the temperature though.
glappkaeft
glappkaeft is offline
#6
Jan19-14, 04:35 AM
P: 82
This paper describes how they did it.
Nanosuit
Nanosuit is offline
#7
Jan20-14, 03:39 AM
P: 8
Luminosity, which is a measure of the total output power of a star(unit: Watts) can be used to find the temperature of the surrounding stars. The luminosity of a star is proportional to its radius and temperature raised to the power 4.That is, L=σ x 4πr2x T4
Wien's law, on the other hand is a direct measure of the surface temperature of the star from the peak wavelength λmof the radiation spectrum emitted by the star.That is,
λm x T = 2.90x10-3 m K
melodyman888
#8
Jan20-14, 11:04 AM
P: 2
Ok this helps guys, still not completely sure how they did it but i will keep trying to figure it out
Thanks, melodyman888
Simon Bridge
#9
Jan20-14, 06:25 PM
Homework
Sci Advisor
HW Helper
Thanks ∞
PF Gold
P: 11,070
Did you want to know how it was actually done, historically, or the methods by which it is done today?
You have been told two things above:
1. the principles by which is possible to discover the temperature of distant objects;
2. The exact method that was used to discover the temperature of this nebula (the link from post #6).
The trouble with the second is that the description assumes you already have a detailed knowledge of the first.
The relationship between the color an object glows and it's temperature is not a simple one and a lot of work had to go into figuring these things out first.
I think, though, that the descriptions of (1) missed something ... you can also tell the temperature of something that does not glow by how dark it is ... and, specifically, in what way it is dark.
When light from a star shines through a nebula - different frequencies get blocked by different amounts. The amounts depend on what the nebula is made of and the nebulas temperature.
If we know what the light is supposed to look like with nothing in the way, then we can figure out the temperature and composition of the bits of the nebula in the way.
In this specific case:
http://www.sci-news.com/astronomy/sc...ula-01493.html
... astronomers used the radiation left over from the "big bang" to do the comparison.
This radiation is much the same from all directions so we know what it is supposed to be.
But where it passes through a cold nebula to get here, it is different.
Register to reply
Related Discussions
find entropy where the temperature is lower than the saturated temperature Mechanical Engineering 2
How does a boomerang work? Classical Physics 4
What causes a boomerang return? General Physics 16
absolute zero for the boomerang nebula? General Astronomy 4
