Brain Tissue Repair: Can You Replace Damaged/Destroyed Tissue?
  • Thread starter Thread starter dreamingofouterspace
The discussion centers on the possibility of replacing damaged or destroyed brain tissue, exploring the complexities of brain tissue transplantation, immune system interactions, and the challenges associated with reconnecting neural circuits.
  • Some participants propose that the brain's immune privilege may allow for tissue transplantation without rejection, as the immune system does not typically enter the central nervous system (CNS).
  • Others argue that while the brain is somewhat isolated from immune surveillance, this does not simplify the transplantation process due to the difficulty in reconnecting neural circuits.
  • One participant mentions the necessity of growth factors for brain cells, which are typically provided by their target cells, suggesting that supplying these factors could aid in re-establishing connections after transplantation.
  • Another participant expresses a belief that transplanted brain tissue could integrate seamlessly into the existing brain, but acknowledges that the reality is more complex than simply replacing tissue and hoping for new connections.
Participants do not reach a consensus; multiple competing views remain regarding the feasibility and mechanisms of brain tissue replacement and integration.
The discussion highlights limitations related to the current understanding of neural circuit reconnection and the role of immune system activation in brain tissue transplantation.
okay I didnt really understand that but what I was wondering was: Can you replace brain tissue that's been damaged or destroyed somehow, since the body (apparently. I had a little bit of trouble understanding that last post) won't reject brain tissue?
Biology news on Phys.org
the brain has a barrier that limit the element enterring the central nervous system (CNS). Usually, cell that play a role in the immune system do not enter the CNS. The CNS has its own immune system (more or less). Therefore, the Major Histocompatibility Complex (MHC) recognition will not play a role when transplanting tissue in the CNS. The rejected tissue is due to non-self MHC that is recognized by the immune system.
While the brain does enjoy a certain isolation from immune surveilance, it is sometimes called an immune priviledged site, this does not necessarily facilitate the type of transplantation you describe. One of the major problems, that we have addressed in other threads, is that physically reconnecting all the circuits in the replaced piece of brain is currently not possible. These connections are critical not only for function of the transplant but also for survival. Chemicals such as growth factors are required by many cells of the brain and are supplied by their respective targets. If these factors can somehow be supplied the transplant might be able to re-establish the correct connections and potentially re-assume function. However this does not mean that the brain is completely devoid of immune activation. Check this article for a review of brain tissue/cell tranplantation and the associated immune system problems.
The only reason I brought it up was I thought that if you put part of someone's brain in the brain... that the brain would sort of automatically connect to it..that that brain tissue would become a part of the brain just like any other tissue, and that it would be looked after by the brain like any other tissue
if that makes sense...sorry if it didnt
It's not a bad thought, and is a fundamental premise behind certain tranplantation technologies that are being investigated. However, it turns out to be more complicated than: replace brain region A with donor piece, hope for new connections to be made and avoid immune system activation. A search on PubMed will bring out more aspects of this topic than can be covered here.
21K
11K
  • · Replies 20 ·
9K
