Register to reply
Water vapor observed venting from Ceres
by marcus
Tags: ceres, observed, vapor, venting, water
Share this thread:
marcus
#1
Jan22-14, 04:37 PM
Astronomy
Sci Advisor
PF Gold
marcus's Avatar
P: 23,232
http://www.bbc.co.uk/news/science-environment-25849871
Herschel space telescope press release:
http://sci.esa.int/herschel/53125-he...-planet-ceres/
Abstract of scholarly article published in Nature:
http://www.nature.com/nature/journal...ture12918.html
Localized sources of water vapour on the dwarf planet (1) Ceres
Michael Küppers, Laurence O’Rourke, Dominique Bockelée-Morvan, Vladimir Zakharov, Seungwon Lee, Paul von Allmen, Benoît Carry, David Teyssier, Anthony Marston, Thomas Müller, Jacques Crovisier, M. Antonietta Barucci & Raphael Moreno
Nature 505, 525–527 (23 January 2014) doi:10.1038/nature12918
Received 23 August 2013 Accepted 26 November 2013 Published online 22 January 2014
The ‘snowline’ conventionally divides Solar System objects into dry bodies, ranging out to the main asteroid belt, and icy bodies beyond the belt. Models suggest that some of the icy bodies may have migrated into the asteroid belt1. Recent observations indicate the presence of water ice on the surface of some asteroids2, 3, 4, with sublimation5 a potential reason for the dust activity observed on others. Hydrated minerals have been found6, 7, 8 on the surface of the largest object in the asteroid belt, the dwarf planet (1) Ceres, which is thought to be differentiated into a silicate core with an icy mantle9, 10, 11. The presence of water vapour around Ceres was suggested by a marginal detection of the photodissociation product of water, hydroxyl (ref. 12), but could not be confirmed by later, more sensitive observations13. Here we report the detection of water vapour around Ceres, with at least 1026 molecules being produced per second, originating from localized sources that seem to be linked to mid-latitude regions on the surface14, 15. The water evaporation could be due to comet-like sublimation or to cryo-volcanism, in which volcanoes erupt volatiles such as water instead of molten rocks.
==endquote==
The water vapor was seen by the European telescope HERSCHEL which operated 2009-2013.
This telescope was positioned at the Sun-Earth L2 point, 1.5 million km straight out from Earth.
If things go as planned, the spacecraft Dawn will arrive at Ceres in March of 2015 and will be able to observe surface features and activity up close.
Phys.Org News Partner Astronomy news on Phys.org
Mixing in star-forming clouds explains why sibling stars look alike
Thermonuclear X-ray bursts on neutron stars set speed record
How can we find tiny particles in exoplanet atmospheres?
Nugso
#2
Jan26-14, 04:26 PM
PF Gold
Nugso's Avatar
P: 156
Hi, marcus. Could you please tell me how we know it's a water vapor? Can we analyze something just by its 'apperance'?
I'm sorry if it's explained in the articles you've shared. I tried waded through them, but couldn't really understand.
D H
#3
Jan26-14, 05:22 PM
Mentor
P: 15,170
Quote Quote by Nugso View Post
Yes. That is the key purpose of remote sensing. Telescopes are, in a sense, remote sensing devices. Chemicals and elements exhibit very distinctive emission lines where the chemical undergoes some quantum mechanical change of state. One of the instruments on the Herschel telescope was a spectrometer. Spectroscopy is a very powerful tool for detecting elements and compounds, even in trace amounts. For example, if the spectrogram shows sharp spikes at 557 GHz and 1113 GHz, that means you are seeing water.
Nugso
#4
Jan26-14, 05:27 PM
PF Gold
Nugso's Avatar
P: 156
Quote Quote by D H View Post
Yes. That is the key purpose of remote sensing. Telescopes are, in a sense, remote sensing devices. Chemicals and elements exhibit very distinctive emission lines where the chemical undergoes some quantum mechanical change of state. One of the instruments on the Herschel telescope was a spectrometer. Spectroscopy is a very powerful tool for detecting elements and compounds, even in trace amounts. For example, if the spectrogram shows a spike at 557 GHz, that means you are seeing water.
Thanks, DH! So, it's kind of similar to the way we find out what kind of atoms the Sun has such as hellium?( I guess I read that part in Lawrence's book "A universe from nothing")
Algr
#5
Feb11-14, 03:03 PM
P: 152
So if Ceres has lots of water, does that make it a better colonization prospect then Mars?
Register to reply
Related Discussions
Pressure Venting in 100% Water System General Engineering 2
Thermodynamics: Cooling Superheated Water Vapor to Saturated Vapor General Physics 2
What is diference between water vapor permeability and water vapor resistance factor? Classical Physics 0
What is the entropy change of ice to water and water to vapor? Introductory Physics Homework 3
Thermodynamics: Water vapor vessel plunged into water ice bath Engineering, Comp Sci, & Technology Homework 5
