What is the Mass of a Thunderhead?
  • Thread starter EskWIRED
  • Tags
    Mass
In summary: The mass of the clouds is just enough to keep the water droplets suspended, rather than rain washing them away.
EskWIRED
99
ISTM that large clouds hold a lot of water, and that water is fairly heavy.
Which got me to wondering just how "heavy" all the water in a large thunderhead would be? I'm assuming that many, many tons of water are floating around up there, but how many?
What does "ISTM" stand for?
Do you have any idea or sources that you've already checked?
Every thunderstorm is different, so I would say no one can say the amount of water, in tons, that a thunderhead contains.
If you stand on your paved street during a thunderstorm, gather up all the rainwater running off in buckets, and then weigh it, what could you infer? Would those measurements tell anything about the total amount that the thunderhead contained?
Rogers and Yau, "A Short Course in Cloud Physics" on page 235 give the mean precipitation content of an isolated thunderhead as on the order of 109 kilograms. They also point out that the actual output during the life of a thunderhead can be more than five times that amount due to the fact that a thunderhead is a process, and not just an object.
Does this answer your question?
It seems to me that ISTM stands for It Seems To Me.
:tongue:
Likes 1 person
:tongue:
Enigman, thank you for your translation. Since I am an "OF" (Old Fart) I needed your help.
Klimatos that is exactly what I
was wondering. Thanks. I find it amazing that so much mass can just float on air.
:tongue:
This is why TSINA (text speak is not allowed) at PF, EskWIRED, please type out text speak.
The density of water vapor is much less than the density of air, at the same pressure. Molecular weight of water = 18, compared with 28 for nitrogen, and 32 for oxygen.
If water vapor was not light enough to "float on air", thunderheads would never form.
Likes 1 person
Water vapor is certainly lighter than dry air. However, the source that I was quoting was referring to the liquid condensate (cloud droplets) content of the thunderhead, not the water vapor content. These droplets are kept aloft by the force of the rising air balancing the downward gravitational force.
This is easier to picture if you think of the thunderhead (and all clouds) as the visible tops of invisible masses of rising air.
1. What is a thunderhead?
A thunderhead is another name for a cumulonimbus cloud, which is a large, tall, and dense cloud that is associated with thunderstorms.
2. How is the mass of a thunderhead determined?
The mass of a thunderhead is determined by measuring the amount of water vapor and ice crystals contained within the cloud, as well as the size and density of the cloud itself.
3. What is the average mass of a thunderhead?
The average mass of a thunderhead can vary greatly depending on its size and location, but on average, a thunderhead can weigh anywhere from 100,000 to 1 million tons.
4. Can the mass of a thunderhead change over time?
Yes, the mass of a thunderhead can change as it grows and develops, and it can also change due to factors such as wind and temperature changes within the cloud.
5. How does the mass of a thunderhead compare to other types of clouds?
Thunderheads are typically much larger and heavier than other types of clouds, such as cumulus or stratus clouds. However, the mass of a thunderhead can also vary depending on its stage of development and the specific weather conditions it is experiencing.
  • Classical Physics
  • Earth Sciences
  • General Engineering
  • Thermodynamics
