Register to reply
Semiconductor Doping
by ChaseRLewis
Tags: doping, semiconductor
Share this thread:
ChaseRLewis
#1
Jan24-14, 10:29 PM
P: 43
I'm aware that you "dope" them with phosphorous for n-type and boron for p-type (I'm aware other materials can be used and other dopants are preferred in other situations). My question is exactly how is this done? Temperature, Pressure, Sputtering, etc.A white paper or something of the exact process would be much appreciated.
Phys.Org News Partner Engineering news on Phys.org
DIY glove-based tutor indicates muscle-memory potential
Tricorder XPRIZE: 10 teams advance in global competition to develop consumer-focused diagnostic device
Study shows local seismic isolation and damping methods provide optimal protection for essential computing equipment
litup
#2
Jan25-14, 08:11 AM
P: 143
Hi Chase! Doping is a process that goes on under the surface layer of the silicon or whatever substrate you are using, gallium arsenide, etc. Sputtering is what you do on the TOP of the surface layer. I work in both regimes. The pressures are high vacuum pressures of 1E-6 torr and in some cases, self focusing beams can use higher pressures. The temperature is just that which does not destroy the substrate so cooling of some kind is usually involved in higher current implants, water cooling inside the substrate housing, single wafer, batch process, etc.
This Wiki can get you started:
http://en.wikipedia.org/wiki/Ion_implantation
Register to reply
Related Discussions
How do the effects of semiconductor doping affect the Hall effect? Atomic, Solid State, Comp. Physics 2
Doping in semiconductor Atomic, Solid State, Comp. Physics 0
Semiconductor Physics : Charge carrier concentration change on doping Engineering, Comp Sci, & Technology Homework 2
Semiconductor doping Atomic, Solid State, Comp. Physics 3
Can any one explain about electron doping and Hole doping Atomic, Solid State, Comp. Physics 1
