Geometry Question - Complex numbers & triangles
The discussion focuses on finding complex numbers that represent the vertices of triangle ABC, given the midpoints of its sides as complex numbers z_1, z_2, and z_3. The user initially considers placing the origin at vertex A, leading to the vertices being expressed as A = O, B = 2*z_3, and C = 2*z_2. However, it is concluded that the choice of origin does not affect the solution, as the problem relates to the properties of similar triangles.
  • Understanding of complex numbers and their geometric representation
  • Knowledge of triangle properties, specifically midpoints and similar triangles
  • Familiarity with coordinate systems and transformations
  • Basic algebraic manipulation of complex expressions
  • Explore the concept of complex number transformations in geometry
  • Study the properties of similar triangles and their applications in complex analysis
  • Learn about the geometric interpretation of midpoints in the complex plane
  • Investigate the use of complex numbers in solving geometric problems
Mathematicians, students studying complex analysis, and anyone interested in the geometric applications of complex numbers.
MattL
OK, I've got this question to do:
Find complex numbers representing the vertices of a triangle ABC given
that the midpoints of the sides BC, CA, AB are represented by complex numbers
z_1, z_2, z_3 respectively.
Thing is, I don't know where I'm taking the origin to be; if I took it at A then I would just have A is O, B is 2*z_3, C is 2*z_2. Surely there's more to the question than that?
Mathematics news on Phys.org
yeah, oops, just realized it's about similar triangle and it doesn't matter where the origin is...
  • · Replies 16 ·
