Calculate Resolving Power of Microscope w/ 1.30cm Aperture
  • Thread starter Thread starter six789
    Circular
The discussion revolves around calculating the resolving power of a microscope with a specified aperture and light wavelength. The original poster mentions a formula related to angular resolution but expresses uncertainty about deriving it and understanding the relationship with light speed in the lens.
  • Participants discuss the necessity of deriving the resolution formula and question the relationship between light speed and wavelength in the context of the problem. There is also a focus on understanding how to apply the given formulas correctly.
Some participants have provided hints and guidance regarding the formulas needed for the calculations. There is an ongoing exploration of the concepts involved, with some participants expressing confusion about the derivation and application of the formulas.
Participants are working within the constraints of the problem, including the specific values given for aperture diameter, wavelength, and light speed in the lens. There is also mention of potential discrepancies between calculated and expected answers, prompting further discussion on conversion between radians and degrees.
six789
Here is the problem...
Calculate the resolving power of a microscope with a 1.30cm aperture using 540nm light. The index of refraction of the lens slows the light inside the glass to 1.98x10^8m/s.
i just know the formula tetha=1.22(lambda)/D, but i don't know how to derive the formula since i don't know any eqaution related to this matter.. Help me please...
Why do you feel you need to rederive the equation for resolution in order to solve the problem?
SOLUTION HINTS:
This is a case of Airy Diffraction from a circular aperture (a special case of Fraunhofer Diffraction). The angular resolving power is (approx) given by:
[tex]1: \ \ \ \ \color{black} \theta_{resolve} \ \approx \ \frac{(1.22)\lambda}{(Aperture \ Diameter)}[/tex]
The difference between λ in air and that in lens glass must also be accounted for:
[tex]2: \ \ \ \ \frac{c}{\color{blue}v_{lens}} \ = \ \frac{\lambda_{air}}{\color{red}\lambda_{lens}}[/tex]
We are given that:
{Aperture Diameter} = (1.30 cm) = (1.3e(-2) meters)
{Wavelength in Air} = λair = (540 nm) = (5.4e(-7) meters)
{Light Speed in Lens} = vlens = (1.98x10^8 m/s)
Solving for "λlens" in Eq #2, we get:
{Wavelength in Lens} = λlens =
= (5.4e(-7) meters)*(1.98x10^8 m/s)/(3.0x10^8 m/s) =
= (3.564e(-7) meters) ::: <---- lens" calculated using Eq #2 with other given values
With Eq #1 above, calculate θresolve using {λ = λlens} and the other given parameter values.
Derivation and discussion of Airy Diffraction from a circular aperture (a special case of Fraunhofer Diffraction) can be found here:
http://scienceworld.wolfram.com/physics/FraunhoferDiffractionCircularAperture.html
A brief overview discussion can be found here:
http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/cirapp.html
(For this latter ref, follow the indicated links for additional info.)
space tiger, what i mean is how can i derive another formula, coz
this is the only formula i know for now... since there is speed, how can i apply it to the formula... can u derive me some formula and can u explain it step by step...
When light travels thru a lens, its speed and wavelength change and are different from those in air. (You may want to review Index of Refraction concepts for more info.) Because the angular resolving power "θresolv" depends on "λ", the light's "λlens" while it travels thru the lens must be used.
All necessary formulas are provided in Msg #3 of this Thread, including Eq #2 which relates light speed "vlens" (<--- value given in problem) and "λlens" for light traveling thru the lens. Study the indicated formulas and calculations, and perform the last computation indicated in RED (with Eq #1) using the calculated value for "λlens" together with the other parameter values listed.
ok xanthym, i get it now... all the whole thing... i can grasp what u mean, but where did the 2nd formula came from in 3rd messsage?? is it a relationship in what?
ok, i seem to understand it, but why is my answer incorrect to the book? my answer is 3.344676923x10^-5 whereas in the book, it is 0.00192 degrees?
Your answer is correct. Convert it to degrees and you'll find it's the same.
u mean to say it is in radians? how can i convert it to degrees? is it divide by 180 or times 180?
ok xanthym, i get the whole concept now... thanks for the effort.. i now understand.. =)
10K
