Which Lifter Bearing is Best for Food Industry Machines
The discussion centers on the optimal bearing choice for food industry machines operating at 30 RPM with a lifter traveling 500mm. Participants concluded that bushings are preferable over linear bearings due to minimal lubrication and the harsh conditions of the food industry. Linear bearings require precise alignment and may fail under side thrust, whereas bushings can last up to three times longer in such environments. This recommendation is based on personal experiences shared by forum members.
  • Understanding of bearing types: linear bearings vs. bushings
  • Knowledge of lubrication requirements in machinery
  • Familiarity with food industry operational conditions
  • Experience with machine maintenance protocols
  • Research the performance characteristics of bushings in wet environments
  • Investigate maintenance practices for linear bearings in food industry applications
  • Explore the impact of side thrust on bearing longevity
  • Learn about lubrication methods suitable for food industry machinery
Food industry engineers, maintenance technicians, and machine operators seeking to optimize the performance and longevity of lifting mechanisms in wet environments.
wolram
Dearly Missed
what is best,a machine we use in the food industry, cycles at
30rpm a direct
drive cam opperates a lifter that travels 500mm up and
down, the machine is washed down every night,there is
no particulate matter.
so would linear bearings or bushes be best for lifter?
"lubrication is minimal"
I'd go with a bushing. My personal experience with linear bearings is that the races move unless precise allignment is maintained. If there's a lot of side thrust a bushing would have to be replaced more often.
thanks for reply GENIERE.
i have come to the same conclusion,linear brgs are excelent
in well maintained environment ,but in harsh wet food industry
bushes seem to last up to three times longer.
  • · Replies 87 ·
11K
