scorpa
- 367
- 1
Hello Everyone,
I am having trouble with the left and right hand rules in Physics. If anyone could explain them to me with as much detail as possible I would really appreciate it. I can tell you what I know and some of what I would like to know if it helps:
The left hand is used for electron flow. Electrons flow from negative to positive and this is the direction that your thumb should point. Your fingers curl up and over the wires to give you the direction of the magnetic field.
The right hand is used for conventional current which flows from positive to negative, your thumb points in the direction of this. Your fingers curl up and over the wires to give you the directoin of the magnetic field.
Here is some of what I want to know. How do you tell which end of the wire is north and south? When is it best to use what rule? And anything else you can give me, I am so lost right now
