What defines the kind of decay an isotope would go for?
by magdi_gamal
Tags: decay, defines, isotope, kind
magdi_gamal
magdi_gamal is offline
#1
Feb1-14, 06:07 AM
P: 9
first, is my initial understanding correct that each isotope go for only a particular kind of decay?
and if so, why? What makes uranium-238 go only for an alpha decay? while uranium 235 go for a fission decay?
Phys.Org News Partner Physics news on Phys.org
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Mapping the road to quantum gravity
Chameleon crystals could enable active camouflage (w/ video)
magdi_gamal
#2
Feb1-14, 06:41 AM
P: 9
and why does uranium-236 decay faster than uranium-235?
jtbell
jtbell is offline
#3
Feb1-14, 07:16 AM
Mentor
jtbell's Avatar
P: 11,255
Quote Quote by magdi_gamal View Post
No, it's possible for an isotope to decay in more than one way. For example, radon-221 can decay either via alpha decay to polonium-217 (about 22% of the time), or via beta decay to francium-221 (about 78% of the time).
Whether a particular mode of decay is possible for a particular isotope, depends on the masses of the decay products.
If the sum of the masses of the decay products is less than the mass of the initial nucleus, then the decay is possible. The "disappearing" mass appears as the kinetic energy of the products.
If the sum of the masses of the decay products is greater than the mass of the initial nucleus, then the decay is impossible as a spontaneous process; energy needs to be supplied from outside in order to create the extra mass.
Spontaneous fission is possible in both U-235 and U-238.
http://en.wikipedia.org/wiki/Spontaneous_fission
magdi_gamal
#4
Feb1-14, 03:20 PM
P: 9
Thanks a lot jtbell, it's clear now.
Register to reply
Related Discussions
Decay of an isotope Introductory Physics Homework 5
Isotope decay, fairly simple. Introductory Physics Homework 5
Question about isotope halflife and decay Introductory Physics Homework 5
Using the decay rate of rubidium isotope to determine age of fossils Introductory Physics Homework 5
certain isotope tell you that the decay rate decreases Introductory Physics Homework 3
