Easy thought experiment imposible fro me
The discussion revolves around a thought experiment involving a ball attached to a cable on a frictionless table, exploring the relationship between tension in the cable, the radius of the ball's circular path, and the ball's linear speed. Participants examine the implications of varying tension on the ball's trajectory, the radius of its path, and the resulting forces acting on the system.
  • One participant calculates the tension in the cable using the formula \( F_c = m \frac{v^2}{\rho} \) and seeks to understand how to adjust the radius while maintaining a constant speed.
  • Another participant expresses uncertainty about how to solve for varying radius and desires to understand the radius variation per turn.
  • Some participants propose that the tension in the cable will differ between inward and outward spirals, suggesting that practical experience contradicts theoretical calculations.
  • A participant speculates on the relationship between radius and tension, questioning how many turns it takes to transition from a radius of 1 m to 100 m under different tension conditions.
  • One participant suggests dividing the ball's trajectory into quarters to analyze the tension experienced during each segment, hypothesizing about the implications for the motion of the table.
  • Another participant challenges the idea that internal forces can lead to unbalanced tensions, emphasizing the conservation of momentum and the role of friction in maintaining position.
  • There is a discussion about the transformation of linear kinetic energy into rotational kinetic energy and vice versa, raising questions about the implications for tension and motion in the system.
Participants express differing views on the implications of tension and radius in the system, with no consensus reached on the correct interpretation of the forces involved or the outcomes of the thought experiment.
Participants note that the radius varies during the motion, and there are unresolved questions about the mathematical relationships governing the system. The discussion includes assumptions about frictionless conditions and the nature of forces acting on the table and the ball.
aviator
i have a ball over a frictionless table tight to a cable tight to a frictionless axe in the middle of the table
if the ball weights 1 kg, the rope is 1 m long and the linear speed of the ball is 100 m/s the tension on the rope will be 10000N (v*v*m/r)
if i want the rope tension to reduce to 100 N keeping the speed of the ball what kind of outwards spiral do i get? can i aply any formula?
if i want the tension to be constantly 20000N what kind of inwards spiral do i get?
thanks in advance to anybody who helps me
:smile:
Use the equation you have already stated and resolve it for rho:
[tex]F_c = m \frac{v^2}{\rho}[/tex]
[tex]100 N = (1 kg) \frac{100 \frac{m}{s}}{\rho}[/tex]
The same holds true for your other question.
the problem is that the radius varies so i don't know how to solve it
what i would really like to obtain is the variation of radius per turn
besides aplying that formula i would get that the Fc of an inwards an outwards spiral (the same medium radius and the same v)would be the same while in reality you just have to spin a weight over your head in an inwards and outwards spiral to notice that the force or tension in the cable to be totally different
may be I am wrong now i think youve helped me a lot
would it be then correct to say rho goes from 1 m to 100m when the Fc is equal to 100N and the speed is 100 m/s and ball weight 1 kg?
now my question is how long or how much turn has it taken it to reach from a radius of 1 m to a radius of 100 m?
i would apreciate very much someone answered to this last question my suposition is a quarter of turn which is yours
i think i have the solution to the problem now:
lest divide the trajectory of the ball in four quarters
in the first quarter the ball goes from a radius of 1 m to a radius of 100 m, let's supose the tension to be 100 N (certainly the force will be lower than 10000N)
in the second quarter the radius goes from 100 m to 1 m i think the tension will be 10000N( certainly the force will be bigger than 100N)
in the 3rd and 4th quarter the tension will certainly be 10000N (being circular the trajectory) and then the first quarter repeats
if we put wheels to the table we have 3 quarters of spin with a tension of 10000N and 1 quarter with 100N
wouldnt that mean that the table would move away from the force of 100N?
and besides if the table was frictionless what would stop the ball to spin and to acelerate the table?
another thing has to be taken into account, in the first and second quarter the ball remains longer in the quarters because the trajectroy is longer being the speed of the ball the same, so the tension of 10000 and 100 N is aplied longer in the 1st and 2nd quarter tha in the rest
this would mean that the aceleration of the table would not only be away from the 100N force of the first quarter but would also go towards the second quarter as well (being the tension in the first quarter just 100 N and in the second 10000 and the time the ball stays in 1st and 2nd quarter the same, the ball will always pull more in the second quarter than in the first)
jesus this is a monologue
Take a huge table on frictionless wheels. Get on it with your ball, cable, and anything else you might like. Spin and twirl the ball any way you want. If you start from rest, the center of mass of the system will stay put. The tension force is internal to the system and won't move the center of mass.
i apreciate and respect your opinion
but your reason is that a postulate says so
its much older the 5th postulate that only one parallel line can go trough a given spot outside the straight line
euclides said so in 300 Bc and it was undiscussed until gauss in 1700 discovered it was wrong but didnt dare to publish it due to the trascendence of it specially with church ideas
it would be lobachewsky in th 19th century who would change the 5th postulate saying that by an exterior point to a straight line infinite parallel lines can go
this meant the separation of linear drawing and mathematics and a revolution
think this mistaken postulated was kept for 22 centuries
Newtons principles are much younger
so postulates can fail
in a circular trajectory the tensions are of 10000N in each quarter the adition of it results 0
in a linear trajectory there would be 10000N in each side which adition gives 0
i have found an example in which the internal forces don't add 0 and it was not easy
and logic deserves a chance in front of faith maybe my idea have not been thought of before
the fact that nobody is able to answer how many revolutions does it take to go from a radius of 1 to a radius of 100m after you switch tension from 10000N to 100N proves this is not studied generally
as nobody studies either in college why by moving your feet a playground swing rocks
Give us a break.
My answer is based upon the conservation of momentum, one of the most experimentally verified laws of physics. It, in turn, is a result of an even more fundamental translational symmetry (see Noether's theorem). It is hardly "a postulate" likely to be overturned just because of someone's confused misunderstanding of elementary mechanics.
Sorry, but your idea about unbalanced tensions in the spiraling ball just won't work. Sure, you can stand there and twirl a ball on a string so that during part of the trajectory the tension pulls harder than another part. But the only thing that allows you to do that is the friction holding you in place. Try doing it without the friction, as a means of propulsion; it won't work.
If you are serious about understanding how swings work (yes, there are some subtleties), there have been many articles published over the years. Go to the library; search through the Amer. Journal of Physics, starting in the late 60s.
I'm moving this to TD. If you are not interested in discussing physics, please stop posting the same rant. It's not going to fly here.
"But the only thing that allows you to do that is the friction holding you in place"
i don't understand this i thought both the table and its wheels were frictionless and i still can hold any tension i want in the cable because the axe is tuck on the table
all right according to conservation of momentum the ball can have any radius and still keep a speed of 100 m/s
but what would happen according actual physics to the balls kinetik energy if the radius was to be 0?
it should spin in the axe having transformated the linear kinetik energy into spinning kinetik energy, it must be this way unless you tell me that energy disapears
so we are onto something new, linear movement can be transformed into spinning movement, linear to spin
would it be very crazy to say the oposite? than spin can be transformed into linear speed?
if this was true we could have one half of the table of linear speed=tension on the axe and the other half of spin= no tension on the axe
so there would be 0 tension in one half and tension in the other
besides according conservation of energy linear kinetik energy can be transformed into spin and therefore probably the oposite as well
if this is true what happens seem so obvious that i won't say it
  • · Replies 35 ·
  • · Replies 17 ·
