| Thread Closed |
characteristic polynomial |
Share Thread | Thread Tools |
| Apr29-05, 02:30 PM | #1 |
So, I have stared at this for a while:
Notation: Q' - inverse of Q, != stands for "not equal"; Suppose A and B are nxn matrices such that A = QBQ' for some invertible matrix Q. Prove that A and B have the same characteristic polynomials I can prove that they have the same determinant, but that is about it. I know that charact. polyn. looks like so: det(A - I*lambda) = det(B - I*lambda) det(QBQ' - I*lamda) = det(B - I*lambda) It would be equal if Q and Q' cancel out, but isn't it true that det(A + B) != det(A) + det(B). I am not sure where to go from here. Is it correct to multiply expressions inside parenthesis by something on both sides? even if it's in determinant I am studying for the final, so any help is appreciated more than ever. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Apr29-05, 02:50 PM | #2 |
Recognitions:
det(QBQ' - kI) = det(QBQ' - Q(kI)Q'), where I'm using k instead of [itex]\lambda[/itex] because it's easier to type. Now, do you see why this equality holds?
Q(kI)Q' = kQIQ' = k(QI)Q' = k(Q)Q' = kQQ' = k(I) = kI, so the equality does hold. Use the distributive property of matrix multiplaction twice, then use the fact that det(ABC) = det(A)det(B)det(C), and you should be done. |
| Apr29-05, 03:20 PM | #3 |
Ohhh, OK. So you also used this identity: AI = IA.
Thanks
| Thread Closed |
| Thread Tools | |
Similar Threads for: characteristic polynomial
| property of characteristic polynomial | Calculus & Beyond Homework | 1 | ||
| characteristic polynomial | Linear & Abstract Algebra | 3 | ||
| Characteristic Polynomial | Calculus & Beyond Homework | 11 | ||
| Characteristic Polynomial in Einsteins Equations | Special & General Relativity | 0 | ||
| Minimal and characteristic polynomial | Linear & Abstract Algebra | 4 | ||
