Register to reply
Dielectric test as per IEC for Low voltage panels
by hisham.i
Tags: dielectric, electric, panels, test, voltage
Share this thread:
hisham.i
#1
Feb3-14, 02:25 PM
P: 177
Hello guys,
I was searching for what voltage does IEC standard call for Di electric test that should be done to low voltage panels? is it 2.5 KV for 1 minutes?
If yes how how low voltage cable rated 600/1000 V can withstand 2.5KV without insulation failure?
Phys.Org News Partner Engineering news on Phys.org
Eye implant could lead to better glaucoma treatment
Electricity helping the blind navigate
Lawsuits challenge US drone, model aircraft rules (Update)
Windadct
#2
Feb7-14, 10:15 AM
P: 564
First be sure to be aware if they are calling out 2.5K VAC or 2.5K VDC -
The cables and equipment must be able to handle voltage higher than the applied voltage to ensure it is safe. For example 600VAC - has peak voltage of 850 V-- and then consider this is 1700V P-P....
There is also the issue of voltage spikes - which could be hundreds of volts.... 2.5KV is the value the industry has accepted as "safe enough" and also economically feasible.
the_emi_guy
#3
Feb7-14, 10:50 AM
P: 588
Which IPC standard is applicable to your equipment?
Register to reply
Related Discussions
Question about capacitor voltage and inner dielectric effects? Electrical Engineering 2
Measuring Voltage from a piezo gas lighter- oscilloscope versus dielectric breakdown? Electrical Engineering 3
Maximum Voltage without causing Dielectric Breakdown? Introductory Physics Homework 3
Why would voltage stay the same when a dielectric is introduced? Introductory Physics Homework 2
Dielectric effect on voltage General Physics 3
