Checking Answers for Comparison Test
The discussion revolves around the Comparison Test for determining the convergence or divergence of series. Participants evaluate specific statements regarding the convergence of given series based on the Comparison Test, focusing on the validity of the arguments presented for each case.
  • Participants analyze the validity of arguments for series A, B, and C, questioning the correctness of inequalities and assumptions made in the statements. Some express initial agreement with the conclusions while others suggest a closer examination of the arguments.
The discussion is ongoing, with participants providing differing opinions on the correctness of the arguments for each series. Some guidance has been offered regarding the need to scrutinize the inequalities claimed in the arguments, particularly for series A and C.
Participants note potential issues with the inequalities presented, especially at specific values of n, and discuss the implications of constants in front of summation signs. There is a recognition of the need for careful analysis of the arguments rather than accepting conclusions at face value.
ProBasket
Each of the following statements is an attempt to show that a given series is convergent or divergent using the Comparison Test (NOT the Limit Comparison Test.) For each statement, enter C (for "correct") if the argument is valid, or enter I (for "incorrect") if any part of the argument is flawed. (Note: if the conclusion is true but the argument that led to it was wrong, you must enter I.)
A.) for n > 2, [tex]\frac{n}{n^3-4}[/tex] < [tex]\frac{2}{n^2}[/tex], and the series [tex]2\sum \frac{1}{n^2}[/tex] converges, so by the comparison test, the series [tex]\sum \frac{n}{n^3-4}[/tex] converges
B.) for n > 2, [tex]\frac{ln(n)}{n^2}[/tex] > [tex]\frac{1}{n^2}[/tex], and the series [tex]\sum \frac{1}{n^2}[/tex] converges, so by the comparison test, the series [tex]\sum \frac{ln(n)}{n^2}[/tex] converges
C.) for n > 2, [tex]\frac{1}{n^2-6}[/tex] < [tex]\frac{1}{n^2}[/tex], and the series [tex]\sum \frac{1}{n^2}[/tex] converges, so by the comparison test, the series [tex]\sum \frac{1}{n^2-6}[/tex] converges
For A.) and C.) sounds true, by the p-series, both converges so that means mean the original series converges, so A.) and C.) are True right?
and B.) I also think it's true by the p-series.
Certainly all the series converge (assuming they start at [itex]n \geq 1[/itex]). I want you to look much more closely at the arguments they present though, and see if you can find anything wrong with any of them.
Data said:
sure you can, for example
[tex]\frac{1}{n^{\frac{3}{2}}} > \frac{\ln n}{n^2} \ \forall n > 0.[/tex]
Their particular argument is obviously wrong, though. If you look at their arguments for A and C, there are problems there too (what happens if [itex]n=3[/itex]? Do the inequalities they claim actually hold?).
Sorry, I pulled my reply because it seemed inappropriate after yours, which I did not know was going to be there. I didn't check their claimed inequality- a serious oversight on my part.
Actually, before I deleted mine I fixed it a little - their argument for A is ok (originally I somehow read it as n^2 in the denominator, or something - but even that doesn't make sense, because I still thought it would converge! Strange, this brain of mine is).
so A is false because there is a 2 in front of the 'sum of' sign(which you can't do)? and B and C are true?
no. A is correct (of course putting the 2 in front doesn't matter! The sum itself is just a number, like any other). Look at our previous posts and then look carefully at the arguments for B and C. Why do you think they are correct?
If a given series A, converges and you compare it against another series say B, in which each member of B is LARGER than A then nothing can be said for the series B.
  • · Replies 21 ·
