Can Gravitational Differential Explain Celestial Rotational Energies?
The discussion revolves around the concept of gravitational differential and its potential role in explaining celestial rotational energies. Participants explore the implications of temperature differentials on gravitational attraction and rotational mechanics, while also considering broader principles in physics and celestial mechanics.
  • One participant proposes that the temperature differential between sunrise (cooler, denser) and sunset (hotter) creates a gravitational differential that could generate rotational effects on Earth.
  • Another participant challenges the claim that mass increases in density as it cools, citing the liquid-to-solid phase transition of water as an exception.
  • A later reply suggests that the temperature differential between the poles and the equator is significant, yet the resulting variation in density is too small to generate notable gravitational effects, questioning the mechanism proposed.
  • Another participant introduces the concept of precession of the equinoxes as a potentially more relevant mechanism than the temperature-based gravitational differential.
  • One participant invites discussion on two principles: a continuous event horizon and an attraction differential that could impart rotation without polarity, seeking their validity and relevance in physics.
Participants express differing views on the validity of the gravitational differential concept, with some supporting the idea and others questioning its feasibility. The discussion remains unresolved, with multiple competing perspectives presented.
Participants highlight limitations in the proposed mechanisms, including the need for further explanation regarding the historical rotational velocity of the planet and the negligible gravitational effects of the temperature differentials discussed.
scott_sieger
HI guys,
Your responses to the post "round and round she goes" has prompted me to post this new thread.
The folllowing is a theory in development thingo but I think very appropriate to the other post. I am sure that if it is more appropriate to post it in the physics theory dev, section that admin will shift it any way. I am going too post it there as well any way if I'm allowed. But in the interests of general discussion on the nature of rotational energies and Celestial mechanics here it is. Your criticisms and counter logic would be welcome.
Gravitational differential.
The Earth and the sun share an attraction called gravity.
The Earth is always in the sun light therefore as the planet spins it is always heating up and cooling down. Sunrise and sunset happening continuously.
The temperature differential being say approximately 20 degrees C...
We know that as mass cools it increases it’s density. We infer that an increase in density also increases the mass’s gravitational attraction.
So therefore on this continuous sunrise (horizon) is a gravitational differential which means that the sunrise ( cooler – more dense) is more attractive than the sunset (Hotter)
This differential imparts a torsional effort on the planet thus generating it’s rotational state.
The above may, in part, explain the rotational effect on matter.
Astronomy news on Phys.org
Not true for water's liquid-to-solid phase transition.
I'm willing to have this kick around here for a bit & let the astro-folks have a go at it before it gets lost in Theory Development.
As there is a much higher temperature differential between the Poles and Equator (about 80 Kelvin difference) you'd expect a shear to take place.
If you care to plug the numbers you'll find that the variation in density os so little that the gravitational effects are negligble. Ergo no spin is generated.
You also need to explain why rotational velocity was larger in the past.
may be we can stand back a little and have a think about the two priciples I am trying to show without reference to the rotation of the planet.
The first is a continuuous event horizon and the second is an attraction differential that requires no polarity yet imparts rotation.
Are these principles valid and are they of any use in any other aspect of physics or celestial mechanics?
  • · Replies 86 ·
9K
  • · Replies 19 ·
  • · Replies 49 ·
