Register to reply
A piston with adjustable resistance?
by nomisme
Tags: adjustable, piston, resistance
Share this thread:
nomisme
#1
Feb8-14, 07:45 PM
P: 19
Dear all,
I have recently come across a project that requires me to find a device that does the following,
A device that:
1)generates "0" movement
2)have a shaft that can be pulled or pushed over a distance
3)I can induce a variable resistance force to the shaft (to counter external motion)
Overall, it should looks like an actuator but the function is different- it can only resist motion and cannot generate motion on its own.
Have you heard of any devices similar?
Phys.Org News Partner Engineering news on Phys.org
Printing the metals of the future
New gadget helps the vision-impaired to read graphs
3D printing helps designers build a better brick
Baluncore
#2
Feb8-14, 10:13 PM
Sci Advisor
Thanks
P: 1,768
An adjustable rate shock absorber as used for vehicle suspension.
nomisme
#3
Feb8-14, 11:39 PM
P: 19
Quote Quote by Baluncore View Post
thanks man
Register to reply
Related Discussions
Adjustable spring? Mechanical Engineering 7
Design an adjustable device Engineering Systems & Design 4
Adjustable Voltage Regulator Engineering, Comp Sci, & Technology Homework 1
Single piston engine problem - position of piston Introductory Physics Homework 8
Oil between the piston and the casing manage to move with the piston? Mechanical Engineering 8
