Calculus Help: Find Volumes & Solve Problems
  • Context: Graduate
  • Thread starter Thread starter gigi9
    Calculus Volumes
This discussion focuses on solving calculus problems related to finding volumes of solids of revolution. The first problem involves integrating the function derived from the curve x^(2/3) + y^(2/3) = a^(2/3) to find the volume when revolved around the x-axis. The second problem requires calculating volumes using the washer method for areas bounded by the curve y^2 = 2x and the axes, revolved around the line x=2. The third problem discusses the volume of a paraboloid of revolution formed by revolving the area under the curve y = H - (H/R^2)x^2 about the y-axis, demonstrating that its volume is half that of the circumscribing cylinder.
  • Understanding of calculus concepts such as integrals and solids of revolution.
  • Familiarity with the washer method for calculating volumes.
  • Knowledge of the properties of parabolas and their equations.
  • Experience with graphing functions and interpreting their geometric implications.
  • Study the method of finding volumes of solids of revolution using the disk and washer methods.
  • Learn how to apply integration techniques to solve problems involving curves and areas.
  • Explore the properties of parabolas, particularly in relation to their revolved volumes.
  • Practice solving similar calculus problems to reinforce understanding of volume calculations.
Students studying calculus, educators teaching volume calculations, and anyone looking to enhance their understanding of solids of revolution in mathematics.
gigi9
Calculus help please!
Can someone please help me to figure out how to do these problems below?...Or at least get me started in the right direction. Thanks a lot for ur help!I would really appreciate ur help!
1) Find the volume of the solid of revolution generated when the area bounded by the given curve is revolved about the x-axis.
x^(2/3)+y^(2/3)=a^(2/3), first quadrant.
****I got to this point: Integral from 0 to a of the
pi*(-x^2/3+a^2/3)^3 dx *** Is this right? what should I do next if it's right?
2)The square bounded by the axes and the lines x=2, y=2 is cut into two parts by the curve y^2=2x. These two are areas are revolved about the line x=2. Find the volume generated.
*** for Volume 1, I have integral from 0 to 2 of pi*[2-(y^2)/2]^2 dy = pi*[4x-2/3y^3+1/20y^5] from 0 to 2 = 64*pi/5 <--ans
*** for Volume 2, I used integral from 0 to 2 of pi*[(y^2)/2]^2 dy = pi* 1/20x^5 from 0 to 2 = 8/5*pi <--ans
Did I do these two problems correctly? If not or any thing wrong, tell me how to fix it... Thanks.
3) If the area bounded by the parabola y=H-(H/R^2)x^2 and the x-axis is revolved about the y-axis, the resulting bullet-shaped solid is a segment of a paraboloid of revolution w/ height H and radius of base R. Show that its volume is half of the volume of the circumscribing cylinder. ****Plz tell me how to get started to this problem, if you can post a graph on here, please show me the graph also. Thank you very very much for ur help!
For problem 1, what you have is correct. What you need to do next is to do the integration! It's probably simplest just to go ahead and multiply (a^(2/3)- x^(2/3))^3.
For problem 2, volume 1, the area is rotated around the line x= 2. The "washer" created by rotating the region between x= 0 and x= y^2/2 has area &pi;(r12- r22) where r1 is the distance from x= 2 to 0 (i.e. 2) and r2[/sup] is the distance from x= 2 to x= y^2/2 (i.e. y^2/2- 2). Your integral should be &pi;&int;02((y^2/2-2)2-4)dy= &pi;&int;02(y4/4- 2y2)dy
For volume 2, you have a disk with radius 2-x= 2- y^2/2.
The formula you are using appears to be rotating around the y-axis.
For problem 3, you certainly ought to be able to graph y= H-(H/R^2)x^2 yourself. That is a parabola with vertex at (0,H) that crosses the x-axis at (R,0) and (-R,0). Of course, since you are rotating it around the y-axis, you only need the portion in the first quadrant.
Each "disk" will have area &pi;x2= &pi;(R2/H)(H-y) (solve y= H- (H/R2)x2 for x2).
The integral for the volume is &int(R2/H);0H(H-y)dy.
Once you have found that, divide by the volume of a cylinder of height H and radius R to find the fraction.
Can you explain more on this one please, where did u get ƒÎç02((y^2/2-2 )2-4)dy ? Where does the "2" inside the () come from?
  • · Replies 16 ·
  • · Replies 20 ·
