Aluminum Properties?
by kq6up
Tags: aluminum, electroplating, properties
kq6up
kq6up is offline
#1
Feb11-14, 10:38 AM
P: 62
I find it strange that Aluminum is high on the activity series but does not react with evolution of hydrogen with many strong acids. I actually tried this when I was a kid. I had access to any acid or salt I wanted. I tried dissolving Al in H2SO4, HNO3, and HCl with no H2 bubbles. Aqua regia absolutely destroyed it. Is this due to the oxide coating on the Al?
Moreover, I have read that it is inert to single replacement of Ag in spent photographic fixer, and that it is recommended to use as an electrode to plate Silver out of spent fixer. I have it in old photographic fixer now, and it does not seem to be involved in any replacement reaction.
Cu would not work as it would be replaced by the Ag out of the fixer, and it would just cause the Ag to precipitate instead of plating out.
Any hints as to what is going on hear would be appreciated.
Thanks,
Chris Maness
Phys.Org News Partner Chemistry news on Phys.org
Space-tested fluid flow concept advances infectious disease diagnoses
New, more versatile version of Geckskin: Gecko-like adhesives now useful for real world surfaces
Researcher develops novel wastewater treatment fabric
Alkim
Alkim is offline
#2
Feb11-14, 02:05 PM
P: 98
Al is indeed very reactive. However, usually it is covered by a thin and compact oxide layer. If you remove that layer and assure it is not formed immediately (e.g. rubbing the surface of the metal with mercury or mercury nitrate), the metal behaves more or less like magnesium, reacting vigorously with air, water and acids. Also, aluminum powder with no previous treatment burns like magnesium when thrown into a flame.
Borek
Borek is offline
#3
Feb11-14, 02:42 PM
Admin
Borek's Avatar
P: 22,673
http://en.wikipedia.org/wiki/Passivation_(chemistry)
kq6up
kq6up is offline
#4
Feb12-14, 10:45 AM
P: 62
It is working. There is grey Ag on the bottom with a Ag colloid hovering above it. The Al electrodes was inert in this process. They look exactly the same.
I think I would rather plate it out than gather a precipitate. Al would be an ideal substrate because it does not dissolve in HNO3 readily. However treating the surface might change that.
My desire is to convert all of this to AgNO3 to experiment with wet plate or tin type photography. I have five gallons of very heavily used fixer. It probably contains well over an ounce per gallon.
Thanks,
Chris Maness
Register to reply
Related Discussions
Aluminum 6063-T6 Material Properties request General Engineering 0
Recover Aluminum from Aluminum Bromide? Materials & Chemical Engineering 0
Material properties influencing laser properties General Physics 0
Can I prepare Aluminum chloride (hexahydrate) solution frm Aluminum chloride powder? Chemistry 5
How does the properties of glass affect its properties?? General Physics 3
