Tensile overpressure ?
by Nick
Tags: fluid force, mechanics of solids, overpressure, tensile
Nick
Nick is offline
#1
Feb11-14, 04:08 PM
P: 1
Hello,
I'm working on how liquid-filled fractures can propagates or be trapped.
I understand that the driving pressure of liquid : Pd = Pm - sigma3
sigma 3 = minimum compressional stress
Pm = (rho_fluid*g*z) + Po = fluid pressure inside the fracture
rho_fluid*g*z = weight of the fluid column
Po = overpressure
But I don't understand how can you trap a fluid-filled fracture in the case of example 4 in the attached document. Since I will need negative overpressure.. and there is no void inside the earth..
thank you
Phys.Org News Partner Engineering news on Phys.org
PsiKick's batteryless sensors poised for coming 'Internet of things'
Researcher launches successful tech start-up to help the blind
Researchers propose network-based evaluation tool to assess relief operations feasibility
Baluncore
Baluncore is offline
#2
Feb11-14, 10:30 PM
P: 1,276
Consider the fluid as a magma derived from gravitational separation of the local melt. That fluid has a density that is less than the surrounding rock. Where there is a significant vertical connection for the fluid there is a differential pressure between the fluid and the rock that forces the fluid to move upwards creating a fracture that may close behind. Fluid can only rise while the fluid is less dense than the surrounding rock. When it reaches a density transition such as the Moho where there is a step change in rock density, the density differential is removed and so stops the upward migration.
In diagram 4 the fluid density is intermediate between crust and mantle. The bubble of fluid therefore stops opening a fracture and halts at the Moho.
Register to reply
Related Discussions
TNT Overpressure and Impulse Calculation Introductory Physics Homework 0
Absolute or overpressure ?? Classical Physics 0
Centrifugal pump suction overpressure Materials & Chemical Engineering 0
Tensile Strength and Tensile Strain Mechanical Engineering 9
Need help calculating overpressure losses for rocket engine Mechanical Engineering 0
