Register to reply
Developing a function/algorithm to negate voltage change
by benanderson08
Tags: developing, negate, voltage
Share this thread:
benanderson08
#1
Feb13-14, 09:24 AM
P: 3
Hey guys,
So in one of my classes we are studying composite materials. We did an experiment where a piece of composite material was anchored at each of it's ends and the temperature was changed throughout the day to simulate the varying outdoor temperature. This gives you a center deflection that is read by a laser and the laser outputs a voltage value.
The problem is that the deflection is meant to measure added weight on top of the composite material at a later date, so the voltage change due to temperature change has to be subtracted from the voltage reading i.e. the original setup with just the ends anchored and no additional weight would yield a constant voltage reading.
So the goal of this assignment is to develop a function/algorithm that would be able to subtract the effects of temperature from the voltage reading in order to keep the voltage constant when there is zero additional weight. This function/algorithm has to apply to both of the days of data attached.
I've tried a few models myself, but if someone could help me with this I would really appreciate it. Any advice would be great as well.
Thank you!!
Phys.Org News Partner Engineering news on Phys.org
Catching grease to cut grill pollution
Researchers develop tool to predict the level of driver discomfort caused by LED lighting
New inexpensive and easy to implement computer software provides real-time and highly accurate data on traffic
.Scott
#2
Feb27-14, 07:09 AM
P: 540
I haven't looked at your data sets, but my first thought is to apply the calibration at the times when the weight is added. So look for abrupt changes and treat those periods of abrupt change as data "holidays". Then extrapolate from the last few data points on either side of the holiday to fill in the missing data and reconnect the pre-holiday and post-holiday data sets into a continuous plot.
Register to reply
Related Discussions
Can't have high voltage function generator. What about low voltage Tesla coil? General Physics 11
A convergence problem when i change a parameter in an algorithm wrote in MatLab Math & Science Software 0
Algorithm for change-making problem General Math 0
Nodal analysis algorithm applied to a circuit without voltage sources Engineering, Comp Sci, & Technology Homework 3
Need Help Developing Algorithm to Decode MathML Computing & Technology 19
