Register to reply
Addition of carbon to cast iron beyond 6.67%
by velmurugan
Tags: >6.67%, 667%, addition, carbon, cast, cast iron, iron
Share this thread:
velmurugan
#1
Feb15-14, 10:08 AM
P: 1
can any one please give me the answer for addition of carbon to cast iron beyond 6.67%..
Phys.Org News Partner Engineering news on Phys.org
Comfortable climate indoors with porous glass
Crash-testing rivets
Customized surface inspection
Baluncore
#2
Feb19-14, 07:19 PM
Sci Advisor
Thanks
P: 1,782
The iron compound with most carbon by weight, 6.67%, is cementite, Fe3C.
Any carbon added beyond that will form flakes of graphite. Those flakes reduce the useful properties of cast iron by making it softer and more brittle.
It is also quite difficult to make cast iron with higher carbon than cementite because it burns. If there were not much better and lower cost materials, it could be formed using powder metallurgy techniques.
There is no advantage in making cast iron with more than 6.67% carbon.
AlephZero
#3
Feb20-14, 08:08 PM
Engineering
Sci Advisor
HW Helper
Thanks
P: 6,966
Quote Quote by Baluncore View Post
That depends what you want to use it for. I used to pass an iron foundry every day on the way to work, where that was their speciality product.
http://en.wikipedia.org/wiki/White_i...able_cast_iron
Baluncore
#4
Feb20-14, 10:18 PM
Sci Advisor
Thanks
P: 1,782
@ AlephZero.
Malleable cast iron has only about 2.5% carbon by weight.
You failed to quote the first line of my post.
I know of no useful cast iron that is composed of only iron carbide with graphite.
Maybe you should examine the phase diagram for Fe – C near the top of the page you link to.
Do you know of any cast iron with greater than 6.67% carbon?
Register to reply
Related Discussions
How to clean cast iron fry pan Chemistry 3
Cast iron and brittleness Materials & Chemical Engineering 4
Cast-iron cylinder Introductory Physics Homework 0
As strong as cast iron but lighter? Materials & Chemical Engineering 1
Why iron from a bloomery has less carbon than iron from a blast furnace? General Engineering 0
