Register to reply
Viscous Drag on a spinning shaft
by nradam
Tags: drag, shaft, spinning, viscous
Share this thread:
nradam
#1
Feb19-14, 10:22 PM
P: 9
I am designing a test rig for my company to test seals.
What i have is a shaft spinning in a fluid column that is pressurized to 30 bar. The shaft is spun by a motor and i am currently trying to figure out what motor i should select. The fluid is a C4 SAE 30 Oil, quite viscous actually. My intuition tells there will be hydrodynamic friction due to the shafts rotation and hydrostatic forces due to 30 bar pressure creating more friction. Can you guys tell me how to figure this out?
In brief the question is -
- 80 mm shaft spinning at 3000 RPM inside a 100mm cylindrical fluid column
- The fluid is SAE 30 Oil
- The oil is pressurized to 30 bar
What is the frictional torque on the shaft ? What is the Power and Torque required by my prime mover (P = Tw anyway ;) )
Thanks in advance. Any help will be appreciated a lot bros :)
Phys.Org News Partner Engineering news on Phys.org
Printing the metals of the future
New gadget helps the vision-impaired to read graphs
3D printing helps designers build a better brick
Chestermiller
#2
Feb20-14, 10:43 AM
Sci Advisor
HW Helper
Thanks
PF Gold
Chestermiller's Avatar
P: 5,060
What's the viscosity of the oil? Does it vary with shear rate? What's the length of the shaft? You may also need to consider whether viscous heating is going to be a factor. You can get an upper bound to the torque by neglecting the viscous heating. Is that acceptable?
Chet
nradam
#3
Feb20-14, 09:20 PM
P: 9
Quote Quote by Chestermiller View Post
Chet
http://www.iocl.com/downloads/servo_..._C4_SAE_30.pdf
The viscosity of the oil is given in that documentation. It varies with temperature, but i dont know whether it will vary with shear rate. The length of shaft is 120mm (inside fluid column). You can neglect viscous heating because when the motor starts the temperature of oil is around room temperature (So like 25-30 C) and the motor has to overcome the torque at that time also.
Thanks a lot if you can tell me how :)
Chestermiller
#4
Feb20-14, 09:52 PM
Sci Advisor
HW Helper
Thanks
PF Gold
P: 5,060
The velocity of the inner cylinder is V=ωRi, where ω is the angular velocity and Ri is the radius of the inner cylinder. The shear rate in the gap between the cylinders is γ=V/(Ro-Ri), where Ro is the radius of the outer cylinder. The shear stress at the wall of the inner cylinder is τ=ηγ, where η is the viscosity. The torque on the inner cylinder is T=2πR2Lτ. The power is P=TV.
(The viscosity is going to be higher at 25C than at 100 C.)
Chet
nradam
#5
Feb21-14, 06:12 AM
P: 9
Okay. You havent considered the effect of pressure in the viscous drag. Wont 30 bar pressure create some effect?
boneh3ad
#6
Feb21-14, 06:43 AM
PF Gold
boneh3ad's Avatar
P: 1,491
No. Pressure will not directly lead to any additional shear stress since it will act only in the direction perpendicular to a given face (i.e. toward the shaft center). The only way it would have an effect is if changing pressure affects the temperature of your oil, and you have already accounted for temperature. Otherwise, the only other way it could affect viscous drag is if pressure affected the viscosity of your oil. I won't say that never happens, but I will say I have never heard of such a fluid.
Register to reply
Related Discussions
Viscous drag and air resistance General Physics 0
Atmospheric viscous drag? Classical Physics 3
Viscous Drag and Terminal Velocity Introductory Physics Homework 2
Calculating viscous drag in water Mechanical Engineering 2
Air Resistance / Viscous drag General Physics 7
