Atmospheric Extinction: How Deep Can 20/15 Vision See?
In summary, looking out a porthole on the ISS, a person with 20/15 vision would not be able to see stars with a magnitude of 12th or 13th. During the war blackout in 1944, amateur astronomers were able to see 8th magnitude stars with the naked eye. The atmosphere attenuates around 90% of starlight, resulting in a 0.28 magnitude reduction per air mass at sea level. Sky glow can also limit visibility of faint objects. The HST, with a CCD camera and long exposure times, can see stars up to 30th magnitude in the visual. On a calm night, the atmosphere's refraction has a smaller impact on what we can see compared
chasrob
185
58
Let's say that you are aboard the ISS looking out a port hole. Far above the atmosphere, how deep should someone of say, 20/15 vision be able to see with the naked eye? 12th or 13th mag.?
I read where, in 1944 during the war blackout, amateur astronomers were able to pick out 8th mag. stars by naked eye.
Astronomy news on Phys.org
12th or 13th mag is far too dim for a person to see with the naked eye. I don't know the exact number, but I doubt you'd be able to see more than a half mag or so fainter outside the atmosphere. Remember that a change in 1 magnitude represents about a 2.5 change in relative brightness.
Only a half magnitude? I recall reading somewhere(it was many years ago, and not on the web--Sky and Telescope?) that outside the atmosphere you could see 3 or 4 mags deeper. That's how I came up with my wild guess--adding that to the wartime dark skies.
I have a VERY hard time believing that you could see 3-4 mags deeper. A magnitude 10 object is only 6% as bright as a mag 7 object, and a mag 11 is only 2.5% as bright. There's no way the atmosphere is attenuating over 90% of starlight.
Likes 1 person
Likes 1 person
I realized that this quote from the article actually fits much better (don't know how I missed the first time).
There are three factors that can be quantitively considered to assess the effect of extinction. Molecular absorption, mainly due to atmospheric ozone and water, is a minor one, about 0.02 magnitudes per air mass. More importantly, Rayleigh scattering by air molecules accounts for up to 0.14 magnitude increases per air mass. Finally, aerosol scattering (dust, water and manmade pollutants) adds about 0.12 magnitudes per air mass. The average total effect at sea level is the sum of these factors, in the order of 0.28 magnitudes per air mass at Standard Temperature and Pressure, (STP = 760 mm Hg, 00 C). Note that stellar objects are, therefore, 0.28 magnitudes brighter at the top of our atmosphere.
Wow, those links are interesting; the refs too. One quarter, or a half magnitude difference only?
The HST can see 30th mag stars in the visual-
https://en.wikipedia.org/wiki/Apparent_magnitude#History
So, if I set up a replica telescope with a 2.5m mirror at sea level, I should be able to see to mag 28,29?
Don't think the Keck can do that, and it's on the top of a mountain.
I must have oversimplified something somewhere.
You are probably not taking into account of the effects of sky glow. Even the best sites possible have an sky glow of 22 magnitudes/arcsec² due to air glow, zodiacal lights and scattered starlight. This has little effect on most objects but it is a real problem when you try to reach the faint stuff.
No. The HST uses a CCD camera and long exposure times to see as deep as it does. Your eye is not capable of this and would not be able to reach the same mag.
Note also the atmosphere doesn't just absorb light, it refracts it, which is what causes stars to twinkle. For our eyes, that effect can change how dim of a star we can see a little -- but not very much on a calm night. For a telescope, even on a calm night that impact is huge (because of their much higher resolution) and will greatly affect the dimmest star they can see.
Likes chasrob
What is atmospheric extinction?
Atmospheric extinction is the phenomenon where light from a distant object is absorbed or scattered as it passes through Earth's atmosphere, resulting in a decrease in the object's apparent brightness.
What causes atmospheric extinction?
Atmospheric extinction is primarily caused by the scattering of light by particles in Earth's atmosphere, such as dust, water vapor, and pollutants. This scattering causes some of the light to be redirected away from the observer, resulting in a decrease in the object's apparent brightness.
How does atmospheric extinction affect vision?
Atmospheric extinction can cause objects to appear dimmer and less distinct to the human eye. This is because the scattering of light in Earth's atmosphere can reduce the amount of light reaching the eye, making it more difficult to see distant objects with clarity.
What is 20/15 vision?
20/15 vision is a measure of visual acuity, or the ability to see fine details at a distance. It means that a person can see at 20 feet what a person with normal vision can see at 15 feet. In other words, someone with 20/15 vision can see objects more clearly and in greater detail than someone with 20/20 vision.
How deep can 20/15 vision see through atmospheric extinction?
The depth at which 20/15 vision can see through atmospheric extinction depends on various factors, such as the amount of scattering in Earth's atmosphere and the distance of the object being observed. However, with optimal atmospheric conditions, 20/15 vision can see objects at a greater distance compared to someone with 20/20 vision due to its ability to perceive finer details at a distance.
  • Biology and Medical
  • General Discussion
  • Earth Sciences
