What are the E, pi, phi constants relations
  • Context: Undergrad
  • Thread starter Thread starter MathematicalPhysicist
    Phi Pi
The discussion centers around the relationships and identities involving the mathematical constants e, π (pi), and φ (phi). Participants explore various mathematical identities, series, and properties related to these constants, as well as their significance in mathematics.
  • Some participants question whether constants like π and e have any significant relationships, suggesting that any perceived connections might be more mystical than mathematical.
  • Others present mathematical identities such as \( e^{i\pi} = -1 \) and discuss its implications, noting its relation to fundamental numbers in mathematics.
  • Power series for π and e are shared, with participants discussing their derivations and computational methods, including the use of scripts for calculations.
  • There is a discussion about the golden ratio φ, its definition, and its appearance in various mathematical contexts, including its relation to the Fibonacci sequence.
  • Participants explore the conditions for summations in the power series and express curiosity about formulas for calculating decimal places of π and e.
  • Some participants express uncertainty about the significance of certain equations and seek clarification on the derivation of constants and their relationships.
Participants do not reach a consensus on the significance of the relationships between the constants. Multiple competing views and interpretations remain throughout the discussion.
Some mathematical identities and series presented depend on specific conditions and assumptions that are not fully resolved in the discussion. The exploration of the golden ratio and Fibonacci sequence also introduces additional complexity that is not universally agreed upon.
do those constants have any relation to each other?
does something like pi-e or pi/e has any significance?
Mathematics news on Phys.org
Well, they are real numbers! Any other relationship I suspect is more "number mysticism" than mathematics. (Phi, in any case, is an algebraic number while e and pi are not.)
yes, there are a few identites in maths such as
ii = e-π/2 and -1 = eπi
If it's any help these are the power series for [pi] and e:
Code:
         r=[oo]
[pi] = 4 * [sum]  ((-1)^r) = 4 - 4 + 4 - 4 + 4
         r=1 (------)       -   -   -   - ... etc.
             ( 2r-1 )       3   5   7   9
And
    r=[oo]
e = [sum]  (   1  ) = 1  + 1  + 1  + 1  + 1           = 1 + 1 + 1 + 1 + 1
    r=1 (------)   --   --   --   --   -- ... etc.           -   -   -- ... etc.
        ((r-1)!)   0!   1!   2!   3!   4!                    2   6   24
[pi] can also be obtained like this:
x * Sin (180/x) where x is a very large number and 180/x is in degrees.
I've attached a script to calculate pi and e using the above power series', however I have not been able to calculate pi using the Sin method as JavaScript assumes that the angle is measured in radians and it does not have a built in Math.pi method to allow me to convert the angle from radians into degrees.
Be careful if you are calculating pi to 1,000,000 iterations, I have an Athlon 1800+ and it caused my PC to hang for a couple of seconds, although I was listening to music at the time.
If you want to view the source, generally in Windows browsers, you can go View > Source.
e(pi)i=-1
Originally posted by mathman
e(pi)i=-1
A few years back I took Complex Analysis from Dr. King, then Chairman of the Lehigh U Math Department. He spent a fair amount of time with this relationship. He preferred to write it
eΠi+1=0
This expression relates 5 of the most important numbers of mathematics, Pi, e, i, 1 and 0 using all of basic mathematical operations, exponentiation, multiplication, and addition. On top of this it is an astounding, nearly unbelievable result.
He considered it poetry in Mathematics.
e(pi)i=-1
i forgot about this equation.
any significance to it?
Code:
         r=[oo]
             ( 2r-1 )       3   5   7   9
And
    r=[oo]
the condition for the summations in both cases is the same, ie r=infinity r=1.
What is phi exactly?
I though it was just another unknown like 'x' 'theta' etc etc
The above formula can also be expressed as
e^(i*x) = cos(x) + i*sin(x)
also 'e' can be derived from
(1 + (1/k))^k
as k approaches infinity, the value of 'e' is more accurate.
Also, if you would like a few million digits of pi, download PiFast and SuperPi and you can calculate them with relative ease :) . a lot of people use these programs to benchmark their overclocked computers and to test stability.
And I put that, what do you think this is:
Code:
    r=[oo]
e = [sum]
    r=1
It's just that if I were to make a script that would run forever you'd never get an answer so what would the point of it be?
Anyway I've re-posted the script if anyone's interested, it includes the (1 + (1/k))^k way to calculate e.
By the way, does anyone know the formula for finding the decimal places of [pi]? I have heard of a formula that when you put in a number (say n, for the nth decimal place), you get an answer. I assume there is one for e as well, so does anyone have that?
The golden ratio, (1 + 5^(1/2)) / 2 = 1.618... is often denoted by the symbol φ.
I've heard of the golden ratio, but what is it used for and why is it golden?
The ancient greeks thought that the most visually pleasing rectangles had their side lengths in the proportion
φ : 1
Such a rectangle, called a golden rectangle, has the property that if you cut a square out of it as follows, the new rectangle has the same proportions as the original rectangle.
Code:
φ, like some other constants, has a tendency to appear in unexpected places. One of the most interesting is the fact that for n >= 0, the n-th Fibbonachi number can be written as:
Fn = round( φ^n / sqrt(5) )
Where "round" means round to the nearest integer.
The exact formula, incidentally, is:
Fn = (φ^n - (1 - φ)^n) / sqrt(5)
Is that assuming that the first two starting numbers are 0 and 1? Is there a formula for finding the nth term for the Fibbonacci sequence that doesn't start with 0 and 1?
I also thought that the sequence was one of those things that didn't have a formula, I wonder where I got that idea from.
Yes, I was using F0 = 0 and F1 = 1.
If you want a different starting point, just substute n with n + k for some k.
What about values such as 0 and 2?
The general solution to the recurrence f(n+2) = f(n) + f(n+1) is:
f(n) = A * φ^n + B * (1 - φ)^n
Hmmm, sorry about chasing you around with this but, if you put in 0 and 1, for A and B respectively, you don't get:
Oh, A and B aren't supposed to be terms 0 and 1; they're constants for which you need to solve.
So I would need the first few terms of the sequence before I could find A and B. OK, fair enough. Maybe I'll find a pattern for the values of A and B for various starting values.
Thanks for the help.
Any two would do, actually. Two equations in two unknowns. You could write down an explicit formula for A and B in terms of f(0) and f(1) if you wanted!
I'll think that I'll save that little treat for another time. Just like last night, I'm tired and I don't work well (or at all) when I'm tired.
Code:
    r=[oo]
e = [sum]
    r=1
is there any reason why this condition applies in both of them?
e(pi)i=-1
another way to write this (which i hope no one has yet written it) is:
e^(i*pi)=-1
e^[(i*pi)/2]=-1^0.5
e^[(i*pi)/2]=i
e^(i*pi)=-1
e^[(i*pi)/2]=-1^0.5
e^[(i*pi)/2]=i
Be careful when doing those sorts of operations with imaginery numbers, but yes that is correct, if you look right back to the start where I gave you a couple of identities you can then put the last term to the power of i which leaves you with the well-known and proved identity of:
ii = e-π/2
If you would like I can post how it is possible to arrive at that solution (by that solution, I mean this - e^(i[pi])+1=0).
It uses the power series of e^x, but replaces x with i[pi], and you wind up with the power series for cos and sin, then when substituting in [pi], you get the equation mentioned above.
It's quite easy to derive (the orginal dervitaion comes from considering the series for cos x, sin x and ex), but it's significance is that it is the special case of x = π in Euler's formula:
eix = cos x + i sin x
Which is one of Euler's identities, the others being:
sin x = (eix - e-ix)/2i
cos x = (eix + e-ix)/2
If you start with 1 and 3 the ratio of consecutive terms approaches phi the fastest (for integers). In fact, each term after the first is round[(phi)^n] : 3 is phi^2, 4 is phi^3, etc. rounded to the nearest integer. If you start with (1, phi) as the first two terms instead of just integers, then the next term is 1+phi which is phi^2, next is phi+phi^2 which is phi^3, etc. (1+5^.5)/2 * (1+5^.5)/2 = (1+2*5^.5+5)/4 = (3+5^.5)/2 = 1+phi. It works!
Aaron
Did you mean phi*phi^2 here.
Arn't those the hyperbolic functions?
cosh sinh?
I might be terribly wrong I am still in high school and we havnt touched this sort of stuff yet. I just like reading maths sites :)
  • · Replies 28 ·
  • · Replies 19 ·
  • · Replies 46 ·
  • · Replies 26 ·
