Water pressure in narrow containers
by mariusnz
Tags: containers, narrow, pressure, pressure narrow box, water
mariusnz
mariusnz is offline
#1
Feb27-14, 08:23 PM
P: 2
I know the general formula for water pressure is related to the height of the water column. But imagine the next situation: A vertical glass tube, 1.0 m high and 100 mm wide, full of water, can support the water inside even with a 0.5 or 1.0 mm thickness wall, but if I have a pool, 1.0 m high and 5 m diameter, I doubt the same wall will be enough to contain the water inside. Why?.The pressure will be the same, as for 1.0 m water column, so how is mass affecting that? I think the basic formula accounts for unlimited back-span. How can I calculate the required wall for a narrow container? What is the back-span from where the formula is OK?
Phys.Org News Partner Engineering news on Phys.org
New ultrasound device may add in detecting risk for heart attack, stroke
Enhanced ground control system and software for small unmanned aircraft
SensaBubble: It's a bubble, but not as we know it (w/ video)
SteamKing
SteamKing is online now
#2
Feb27-14, 09:39 PM
HW Helper
Thanks
P: 5,601
The pressure of a fluid depends only on the depth of fluid and the density of the fluid.
However, when you are designing a container to hold X amount of water or other fluid, it is not sufficient to know that the pressures are the same in a small container versus a large container. The total load produced by the pressure on the container walls determines, in part, how strong the container must be made to prevent collapse.
You have a structural design problem to solve. The type of loading has a bearing on the solution, but it is not the only factor which must be considered.
Chestermiller
Chestermiller is online now
#3
Feb27-14, 09:47 PM
Sci Advisor
HW Helper
Thanks
PF Gold
P: 4,508
Quote Quote by mariusnz View Post
The force of the pressure is supported by tensile stress present within the walls. From a force balance, the tensile stress is equal to pR/t, where R is the radius of the container and t is the wall thickness. So to support a given pressure, the ratio of the radius to the thickness has to be the same for the pool as for the tube (if it is made of the same material). So a bigger radius requires a bigger wall thickness. The tensile stress must not exceed to ultimate stress of the material.
AlephZero
AlephZero is offline
#4
Feb27-14, 10:04 PM
Engineering
Sci Advisor
HW Helper
Thanks
P: 6,388
The pressure only depends on the fluid depth.
If you have a cylindrical pipe or container, the stress in the radially-outwards direction varies from same as the fluid pressure, on the inside to zero on the outside. That component of the stress is very small and won't break anything.
But there is also a stress component acting around the circumference of the cylinder. That is much bigger and depends on the radius and thickness of the cylinder. Imagine you cut the pipe into two half-pipes with a vertical plane. The total "sideways" force of the fluid, on a thin vertical strip of thickness h, 2Prh where r is the pipe radius and P is the pressure. (Assume h is small enough so the pressure on the thin strip is constant).
That force has to be resisted by the tension in the pipe, which is 2Sth where S is the circumferential stress and t is the thickness. So S = Pr/t. (The above assumes the thickness t is small compared with the radius r. Otherwise, the math gets more complicated but the general idea is the same).
So, as a simple approximation, if you double the radius, you double the minimum thickness you need to resist the same water pressure, or the same water depth.
Chestermiller gave you the short version of this answer, while I was typing the long version!
SteamKing
#5
Feb27-14, 11:42 PM
HW Helper
Thanks
P: 5,601
Quote Quote by AlephZero View Post
Don't forget the density of the fluid. 760 mm Hg makes a higher pressure than 760 mm H2O.
mariusnz
mariusnz is offline
#6
Mar2-14, 01:18 PM
P: 2
OK, thank you very much.
Register to reply
Related Discussions
Finding pressure at narrow end of segment Introductory Physics Homework 4
pressure and force in 3 different containers Introductory Physics Homework 5
Containers Structurally Able to Hold Freezing Water? Classical Physics 25
Difference of pressure of fluids in containers. Introductory Physics Homework 2
Difference of pressure of fluids in containers. General Physics 2
