Register to reply
Pressure change with time.
by sambyrd220390
Tags: pressure, time
Share this thread:
sambyrd220390
#1
Feb28-14, 05:32 AM
P: 1
I have a storage tank of 40 litres with compressed air, compressed to 9 bar (absolute), which is then fed through 8mm diameter pipe to a motor. The final pressure of the air is atmospheric (1 bar). The system is run until the storage container is depleted. Is there an equation that can find the time to take until the air runs out? Also i would like to plot this as a function of time, is there an equation to do this? I am assuming that temperature is constant.
Phys.Org News Partner Engineering news on Phys.org
DIY glove-based tutor indicates muscle-memory potential
Tricorder XPRIZE: 10 teams advance in global competition to develop consumer-focused diagnostic device
Study shows local seismic isolation and damping methods provide optimal protection for essential computing equipment
mfb
#2
Feb28-14, 01:31 PM
Mentor
P: 11,925
Is there some valve to reduce the pressure? The motor could block the air flow somehow.
There are ways to calculate this, but I'm not sure how the setup looks like.
How long is your pipe?
The temperature of the expanded air will be below room temperature.
Chestermiller
#3
Mar1-14, 07:19 PM
Sci Advisor
HW Helper
Thanks
PF Gold
Chestermiller's Avatar
P: 5,256
Quote Quote by sambyrd220390 View Post
You need to determine the pressure drop-flow rate relationship for the pipe. If there is a valve, you need to determine the pressure drop-flow rate relationship for the valve. You then do a mass balance on the tank, and couple this with the ideal gas law and the pressure drop-flow rate relationships. This allows you to solve for the pressure in the tank as a function of time.
Chet
Register to reply
Related Discussions
Calculate new boiling point with change post-pressure change Advanced Physics Homework 4
Change in Density due to Temperature and Pressure Change Introductory Physics Homework 6
Pressure Change over time PV=nRT General Physics 0
Required change in pressure to change volume Introductory Physics Homework 5
Change in fluid levels in a manometer given a pressure change Introductory Physics Homework 0
