Estimating internal (junction) temperature
The discussion focuses on estimating internal junction temperature (Tj) in a motion sensor housed in a sealed metal enclosure. The user, Eli, employs an external temperature sensor to calibrate temperature offsets, but encounters issues during rapid temperature changes, particularly in the first five minutes after powering the device. Eli seeks a straightforward method to estimate Tj, given that Tcase equals Tj before powering up the sensor. The need for reliable estimation techniques in dynamic thermal environments is emphasized.
  • Understanding of thermal dynamics and temperature gradients
  • Familiarity with temperature calibration techniques
  • Knowledge of sensor technology and enclosure effects
  • Experience with data logging and analysis tools
  • Research methods for estimating internal temperature in sealed enclosures
  • Explore thermal modeling techniques for electronic devices
  • Investigate the use of thermal imaging for temperature measurement
  • Learn about advanced calibration methods for temperature sensors
Engineers, product designers, and technicians involved in sensor development, thermal management, and calibration processes will benefit from this discussion.
Eli Hait
Hello.
I use a kind of motion sensor located in a sealed metal enclosure.
I perform temperature offset calibrating to this device, using an external temperature sensor (attached to the enclosure). This solves the most of temperature problems except when the temperature gradient is large - for instance for 1'st 5 minutes afrer powering the device.
After checking this issue my conclusion was that in fast temperature gradients the temperature delta between the case temperature (Tcase, the one i measure) and internal (Tj) temperature is too large so i don't compensate the real offset error.
My question is if there is a simple method to estimate the internal temperature (Tj), if at the beginning (before powering up the sensor) the external and internal temperatures are equal Tcase=Tj.
Is there good information about it on the web?
Thanx,
Eli.
someone... please...
  • · Replies 152 ·
12K
