Register to reply
Li-Ion Battery Efficiency
by Timeforheroes0
Tags: battery, efficiency, liion, lithium ion
Share this thread:
Timeforheroes0
#1
Mar1-14, 06:37 AM
P: 9
Hi,
I am trying to figure out how Li-Ion batteries operate in regards to efficiency. I understand they have rated voltage and current etc. and to operate them at these parameters if possible. However, i'm wondering is it simply the current that has effect on their efficiency. By Efficiency I mean the amount of energy leaving the battery that get transferred to the appliance divided by the amount of energy leaving the battery.
Is the energy dissipated in the battery solely due to heat dissipation?
If it's operated below rated voltage what effect does this have?
I also understand that Li-Ion operate better at higher temperatures, but does this not just mean that they operate at a higher voltage at these temperatures but aren't actually more "efficient"?
Thanks for any help, trying to get my head around this!
Phys.Org News Partner Engineering news on Phys.org
Tricorder XPRIZE: 10 teams advance in global competition to develop consumer-focused diagnostic device
Study shows local seismic isolation and damping methods provide optimal protection for essential computing equipment
New filter technology uses inert gas to bore holes in high-quality steel
mfb
#2
Mar1-14, 07:21 AM
Mentor
P: 11,900
Heat is where the energy mainly ends up, yes. Maybe some unwanted chemical reactions in addition, especially if it gets hot.
This is the same as operating it above the rated current.
I would expect more efficiency, but not a higher voltage at zero load.
Timeforheroes0
#3
Mar1-14, 07:36 AM
P: 9
Quote Quote by mfb View Post
Ok, I see. Why is voltage below rated voltage the same as operating it above the rated current?
Is there anyway of quantifying battery losses beyond P=[itex]I^{2}[/itex]*R?
Thanks!
mfb
#4
Mar1-14, 07:47 AM
Mentor
P: 11,900
You can approximate the battery as a perfect power supply with an additional resistor in series. A larger current will lead to a larger voltage drop at this (virtual) resistor, so the output voltage goes down.
Battery loss is then given by I2R = I(U-U0) with the zero load voltage U0.
Register to reply
Related Discussions
Mylar to increase efficiency of solar battery charger? General Engineering 1
Comparing Carnot efficiency to Stirling efficiency Introductory Physics Homework 1
PV Diagram Problem (ideal efficiency vs actual efficiency) Introductory Physics Homework 2
Battery efficiency and internal energy Introductory Physics Homework 0
Isentropic efficiency vs polytropic efficiency of a gas turbine Aerospace Engineering 6
