Simulating weight through coils
  • Thread starter Thread starter vidin
    Coils Weight
The discussion revolves around the challenge of creating a controllable weight system that simulates a weight range of 10kg to 250kg. Participants explore various methods to achieve this through mechanical and electronic means, including the use of coils, pneumatic systems, and other devices. The conversation includes technical details and practical considerations for implementation.
  • Some participants suggest using coils based on Lorentz forces, while others seek clarification on the type of coils being referenced.
  • A participant proposes using pneumatic cylinders controlled by a digital pressure regulator to simulate weight.
  • Another idea involves using a water tank to dynamically adjust weight through a pump, though this is later dismissed due to noise concerns.
  • One participant discusses the potential of an electromagnet and plunger system, suggesting that varying input voltage could control the force exerted.
  • Concerns are raised about the feasibility of controlling the system accurately and the high current required for simulating significant weights.
  • Participants discuss the possibility of using a frictional device, such as disk brakes actuated by a motor, to create variable resistance.
  • Questions are posed regarding the design parameters, including weight range, motion requirements, and precision needed for the system.
  • Suggestions for further reading on pneumatics and leverage physics are made to aid in understanding the concepts involved.
  • A spring and fulcrum mechanism is proposed as an alternative, with concerns about safety and control of the fulcrum being raised.
Participants express a variety of ideas and approaches, with no consensus on a single solution. Multiple competing views on the best method to achieve the desired controllable weight remain unresolved.
Participants highlight several unknowns that complicate the design, including the required weight range, motion dynamics, and precision of control. These factors contribute to the complexity of the proposed solutions.
Individuals interested in mechanical engineering, control systems, and physics applications may find this discussion relevant.
vidin
Hello everyone,
I have a little practical question. I would like to create a weight of about 10kg-250kg. A software programm should be able to control the actual weight.
Does anybody know a good physical way to do that? I thought of coils using Lorentz but I'm not quite shure.
Any help is very appreciated. Even if just a little thought.
Thank you very much.
vidin
I have no idea of what you are talking about. Coils? Do you mean springs? Electrical coils?
Create weight? please explain.
I'm sorry. Probably I didn't explain very well. But let me give it another try:
For a machine, I'm trying to create a construction which can "build up" weight dynamically.
It's basically replacing a real weight with one I can control.
How heavy the actual weight at a specified time is is then being controlled through a software system.
Please don't hesitate if there are still questions left.
Thanks in advance.
to change the weight of anything; you'd either have to change its mass, the mass of the earth, or the universal gravitational constant.
Perhaps you could use a pneumatic cylinder, or cylinders, with input from a digital controlled pressure regulator. Check out the
Marsh-Bellofram products for regulators (I KNOW, from personal use, that they make one with good digital control up to ~170PSI.
Look to Bimba or SMC for pneumatic cylinders
Thanks for the apropriate answer. (Not like Fuego who just thinks he's funny).
I will check it out!
Well I think I'm on the right way to describe it right. Let me now describe my problem very precise:
The module I need has a black box and a bar hanging outside. The user's task is now to pull the bar which should be about 1.5meters long. How strong it is to pull the bar depends on what the user set up on a computer system/user interface. So I have to control the force which is needed to pull the bar via software.
That's it. That's my big problem which needs to be solved. But just how? I have no clue!
Thank you very much for your help. I really appreciate it!
vidin
I can think of many ways to do it, but the easiest way I think would be…
Attach your lever to a water tank. Use your software to control a pump to add or remove water to achieve the desired weight. Feedback to the software could come from a float in the water connected to a potentiometer as the height of water can be related to the weight.
Well, Fuego is right. It's a language issue as far as I can see.
Weight is the force acting on an object due to gravity. You can't increase or decrease this without increasing the mass or moving the object up or down in the gravity field.
Force is the word you wanted to use.
The watertank idea doesn't work as it is too loud (shouldn't be heared at all when changing the force). But still thank you Geniere, I'd really love to hear your other ideas as I have none :smile:
vidin
I'm not too sure how accurately this can be controlled, but perhaps an electro magnet and plunger system could be controlled by varying input voltage ot amperage. I believe this could be computer controlled so that when more power is applied the magnet pulls harder on the plunger.
I think it would have to be a plunger with a rod through the coil to keep some portion of each surface in contact through the entire motion or else you would get a hard to control spring like motion.
@Artman: could you explain a little bit more? What kind of plunger system? It's hard for me because I actually speak German and don't know all the technical terms. A link or a description how it looks like or work would be awesome!
Thanks a lot!
I think Artmans concept could be made to work, but fabrication would be difficult and the current would be quite high to simulate many kilograms of weight.
Perhaps a frictional device could do the job. I may be possible to get a set of disk brakes and a rotor from a motorcycle or automobile and adapt it to be actuated by a motor driven cam. I would use a stepper motor. I don't have an easy solution to provide feed back to the software, so calibration would have to be done often.
As to my previous suggestion, the pump does not have to be located in the box and can be placed out of hearing range.
It would be helpful to know the purpose of the device.
This is a good idea. Sorry Integral, I didn't notice this response before.
With proper use of levers, this could easily apply hundreds of pounds of simulated weight and control of pneumatic devices is fairly precise.
Hi Artman&Integral,
could you please explain a little bit more as I still don't really know how to put things together.
vidin
There are too many unkowns to design this instrument.
1. What is the weight range? Hundreds of lbs, or just a few?
2. What is the range of motion required?
3. Should the apparent weight applied to the arm appear constant through the entire range of motion or can it change?
4. How quickly does the system have to set?
5. How quickly does it need to reset?
6. How precise do the measurements need to be?
7. What level of modulation is required for the weights? (How small do the increments need to be?)
These are just a few of the questions. I would recommend that you do a little reading on pneumatics to see what they are capable of, and see if you think they can serve your idea.
I will definitely! Could you recommend me some books or any literature which would help me archiving that goal? Would be fantastic!
To your questions:
10kg - 250kg (see above)
1-2m (see above)
No, need to be changeable while pulling
Changing the force needed to pull should be done in seconds and less.
Instantly.
about +/- 2kg would be good
5kg each step.
Thanks for your help once again!
vidin
The sites that Integral posted in his response are a good starting point.
Also do some reading on the physics of leverage, to figure out the best placement of the pnuematic devices in relation to the arm.
I had another thought on this idea.
How about a spring attached to one end of the bar and a fulcrum that can be moved to change how much force is required to pull the bar?
First of all : you're awesome! I really appreciate it that you guys help me finding a solution!
@Artman: A special thanks to you!
I think I understand what you mean. But how would you control the fulcrum? Maybe installing on a pneumatic cylinder and control the cylinder? It also sounds a little bit dangerous to me because when something happens with the spring the customer could be injured.
Please let me know if you guys have any more ideas! I will try all out and present my solution here once it is done.
vidin
The range of motion and forces you need is daunting. That is going to require some major machinery. Pneumatics does not do well with multi-positions, it is either on or off, so you would need to figure out some way to position your device, pneumatics could then apply a static pressure.
As for instantly, forget it, this is the real world there is going to some delays in a system of this magnitude.
Robotics and servo control are developed well. Seek for these things. Linear Motor, brushless synchronous motors, smooth stepper motors. I'd go for things like that.
Ever tried ForceFeedback gaming wheel? Its synchro motor controlled by pulsed modulated signal. Its effectively smooth, well dosated, and nearly instant. Bigger is more powerful ;)
Sorry, my German is a bit rusty.
Is there any particular geometry you had in mind for the device?
Is it supposed to be a black box with a handle sticking out, or more like a barbell/pullup bar?
Is it important to be able to set the default height?
Do you want the system to be double acting?
Does it need to respond to motion in any particular way?
Does it need to be programmable?
Based on the location of the bar?
What kind of duty cycle is this thing expected to handle?
Do you have any particular construction method in mind?
Do you intend to mass produce?
Entschuldigen sie bitte meine fehler. Ich habe seit langem kein Deutsch geschrieben.
Dachten sie an eine training Machine als sie dieses Project beschrieben? Wie w¨rde man dieses Gerät benutzen? zum bsp. liegend, sitzend, oder stehend?
Ist es wichtig das die Anfangshöe eistellbar ist?
Wollen sie das Gewicht auch ziehen, oder nur heben?
Soll es auf bewegung reagieren?
Soll es programierbar sein?
Wie oft und schwer würde dieses gerät benutzt werden?
Wie wollen sie diese Machine herstellen?
  • · Replies 27 ·
  • · Replies 16 ·
  • · Replies 23 ·
  • · Replies 26 ·
