Register to reply
Why the order of operations?
by S_David
Tags: operations, order
Share this thread:
S_David
#1
Mar1-14, 06:02 PM
P: 599
Hi,
I am wondering why the order of operations where made? Is it the case that mathematics is just a tool of solving physical problems, and hence the order is physically defined? For example, if I say: I took 3 apples from 9 apples and divided the rest to two persons equally, I won't write this mathematically as: 9-3/2 but rather (9-3)/2. Right? In other words, the vague order of operations doesn't appear when solving physical problems using mathematical tools.
Thanks
Phys.Org News Partner Mathematics news on Phys.org
Heat distributions help researchers to understand curved space
Professor quantifies how 'one thing leads to another'
Team announces construction of a formal computer-verified proof of the Kepler conjecture
micromass
#2
Mar1-14, 07:49 PM
Mentor
micromass's Avatar
P: 18,323
The "order of operations" isn't really of much mathematical importance. It's just defined to make notation easier (and boy, does it make notation easier!!).
For example, something like ##2+3x^3## is well-defined and requires the order of operations to interpret. If we don't like to define some order of operations, then we should denote it as
[tex]2+(3*(x^3))[/tex]
So we would need brackets in order to clarify the order we want to do things in.
Obviously, this notation is very much tedious and annoying. And this is exactly where the order of operations comes in.
Does that answer your question?
D H
#3
Mar1-14, 08:44 PM
Mentor
P: 15,170
It's more than just a matter of convenience. It's rooted in the fact that with numbers as most people know them, multiplication distributes over addition: (a+b)*c = (a*c)+(b*c). Addition does not distribute over multiplication (boolean algebra excepted).
S_David
#4
Mar1-14, 10:15 PM
P: 599
Quote Quote by micromass View Post
OK, that makes sense. Thanks
S_David
#5
Mar1-14, 10:15 PM
P: 599
Quote Quote by D H View Post
I am sorry, I didn't get this one. Can you explain more, please?
Mark44
#6
Mar2-14, 11:28 AM
Mentor
P: 21,304
What D H is saying is that addition doesn't distribute over multiplication. IOW,
(a * b) + c ##\neq## (a + c) * (b + c)
Multiplication does distribute over addition, so it's true that (a + b) * c = (a * c) + (b * c).
arildno
#7
Mar2-14, 02:22 PM
Sci Advisor
HW Helper
PF Gold
P: 12,016
Well, there is nothing intrinsically wrong with having in default, non-parenthesis notation addition bind more tightly than multiplication.
But, the law of distribution would then get an UGLY, and not the least, confusing form:
a+b*c=(a*c)+(b*c)
Letting multiplication have priority over addition simplifies the expression for the distributive law, and prevents a lot of mistakes that would be made if we reversed order of operations.
micromass
#8
Mar2-14, 02:31 PM
Mentor
micromass's Avatar
P: 18,323
Quote Quote by arildno View Post
a+b*c=(a*c)+(b*c)
Maybe it's confusing because we're more used to the alternative /DevilsAdvocate
One other motivation is when working with units. You want to write things like ##10m##, and this is some kind of multiplication. So it makes sense to bind multiplication closer together than addition. I mean, you don't want to write
[tex]10 + 20m[/tex]
instead of
[tex](10 + 20)m[/tex]
And something like [tex](10m) + (20m)[/tex] is also not very nice.
arildno
#9
Mar2-14, 04:50 PM
Sci Advisor
HW Helper
PF Gold
P: 12,016
Of course, if we make default invisible addition sign, we'd get something not half-bad like this:
ab*c=(a*c)(b*c)
micromass
#10
Mar2-14, 04:56 PM
Mentor
micromass's Avatar
P: 18,323
ab*c=(a*c)(b*c)
I like that!
jing2178
#11
Mar4-14, 03:41 AM
P: 41
The order of operations does make sense in the physical world. In your example there are 9 apples and 3 apples are taken away before the apples are shared between 2 people. Thus the subtraction 9 apples take away 3 apples to give 6 apples is done first then the 6 apples are shared between the two people who get 3 apples each.
Think of the physical space where the apples are kept.
I put 9 apples on a table, 3 are removed from the table (perhaps they have been eaten), the remaining 6 on the table are shared between 2 people.
In the mathematical model how do we represent the physical space, the table. We could use a line for example 9 - 3 / 2 but in practice we use brackets to represent the physical space in which items exist so (9 - 3)/2
Without brackets we can assume that the numbers represent objects in the same physical space so in this case 9 - 3/2 would model 9 apples on the table from which three half apples have been removed, since - is always applied to two quantities or numbers and the two numbers shown are 9 and 3/2.
S_David
#12
Mar4-14, 09:25 AM
P: 599
Quote Quote by jing2178 View Post
Yes, but you are trying to understand the physical world from the mathematical equations. But if I told you the physical problem and write it mathematically as 9-3/2 you know that the answer would be 3. Right?
D H
#13
Mar4-14, 02:42 PM
Mentor
P: 15,170
Quote Quote by S_David View Post
Wrong.
S_David
#14
Mar4-14, 02:44 PM
P: 599
Wrong.
Why?
lendav_rott
#15
Mar4-14, 03:09 PM
P: 223
9 - 1.5
anyway, a good question here would be: Why exactly does multiplication take priority over addition?
arildno
#16
Mar4-14, 03:40 PM
Sci Advisor
HW Helper
PF Gold
P: 12,016
Quote Quote by lendav_rott View Post
It doesn't. If we use parentheses.
The priority rule is established so that we may escape tedious parenthesis writing in about "half" the cases.
lendav_rott
#17
Mar4-14, 11:08 PM
P: 223
Yes, but suppose I'm a complete math illiterate. How would you explain without parenthesis, that 10 - 5 / 5 = 9 not 1? There are no brackets, yet multiplication comes before addition, why is that?
jing2178
#18
Mar5-14, 03:56 AM
P: 41
It could have developed that arithmetic was calculated from left to right so that 2 + 3 * 5 = 25
and to show that the multiplication needed to be done first then you would write 2 + (3 * 5) = 17
So why not this and why multiplication first? Mathematics did arise from the physical world.
Buying some goods from a market stall selling fruit calculations would be done as
(I'm English so cost in pence)
1 apple @ 10p 10p
5 oranges @ 12p 60p
3 bananas @ 15p 45p
Total 115p
In doing this the multiplications have to be done before the adding.
Also
If you have a boat and 3 crew you have a boat and 3 crew. You are counting different things so adding the 1 for the boat and 3 for the crew does not make sense.
So if you have one Two and three Fives you cannot immediately add the 1 and 3 since you are counting different things Twos and Fives.
However unlike boats and crews Twos and Fives have something in common - Ones.
A Two is two Ones
A Five is five Ones
So if I can change three Fives into a count of Ones then I can count all the Ones and work out how many Ones there are in one Two and three Fives
three Fives is five Ones and five Ones and five Ones, since now I am counting the same things (ie Ones) I can add the fives to get fifteen Ones
so one Two and three Fives is the same as two Ones and fifteen Ones which is seventeen Ones or one Seventeen.
Since you can only add quantities together if you are counting the same item you need to change the Two and three Fives to Ones. To do so the multiplication as repeated addition needs to be done first. So giving multiplication priority over addition makes sense.
Register to reply
Related Discussions
Min and max in order of operations General Math 5
Order of Operations Precalculus Mathematics Homework 4
Order of Operations General Math 5
Order of operations Introductory Physics Homework 3
Order of operations General Math 6
