Explain the logic behind proportions
  • Context: High School
  • Thread starter Thread starter quasar987
    Explain Logic
The discussion revolves around the logic behind proportions, particularly in the context of weight and height relationships. Participants explore how to explain these concepts to beginners, using examples such as the weight of a gorilla and King Kong. The scope includes conceptual explanations and mathematical reasoning.
  • One participant suggests using the ratio of weight to height to explain proportions, proposing that the gorilla weighs 2 kg at 46 cm, leading to the calculation for King Kong's weight as 1800*2/46.
  • Another participant argues that weight is not directly proportional to height but to body volume, which scales with the cube of height, suggesting a different formula: (1800/46)^3*2.
  • Some participants propose using relatable examples, such as pricing or geometry, to help beginners understand proportions.
  • Concerns are raised about the validity of the original example, with one participant questioning the realism of King Kong's weight in relation to his height.
  • Discussion includes a critique of the assumptions made in the example, emphasizing the need for sanity checks in modeling real-world phenomena.
  • Participants also discuss the implications of scaling in terms of strength and movement, noting that strength scales with the square of length while weight scales with volume.
Participants express disagreement regarding the proportionality of weight to height, with some advocating for a direct proportionality and others emphasizing the importance of volume and cubic relationships. The discussion remains unresolved, with multiple competing views presented.
Participants highlight limitations in the original example, noting that it oversimplifies the relationship between height and weight. There is also mention of the need for sanity checks when modeling physical phenomena.
quasar987
I'm trying to explain the logic behind proportions to someone who's just learning this stuff and find it very difficult to give a simple explanation.
exemple: A 46 cm tall gorilla weights 2kg. Approximately how much would king kong weight if he's 1800 cm tall?
How would you justify that the answer is 1800*2/46 ?
Mathematics news on Phys.org
The justification is by saying that the gorilla weighs [tex]\frac{2}{46}\frac{kg}{cm}[/tex]
I would say that this is the "average weight per unit". Once the person you are helping sees that proportion tell them to do the inverse, if the gorilla weighs [tex]\frac{2}{46}\frac{kg}{cm}[/tex], how much does he weigh if he is 46cm tall?
[tex]\frac{2kg}{46cm}*\frac{46cm}{1} = 2 kg[/tex]
And then hopefully he/she can see the connection.
And then finally you can move on to the problem with 1800 cm.
Jameson
Prices usually help.
One oragne costs $3. How much will five oranges cost? Then set it up as Jameson showed and it should click. Prices are things they deal with all the time.
Two good ideas, thank.
If they like geometry, you could use similar polygons. A few examples with rectangles and triangles should be enough.
This is a really bad example! You can't justify that answer- it's wrong!
Weight is not proportional to height, it is proportional to body volume which is itself proportional to height cubed. The correct answer is (1800/45)3*2.
If you want the postal address of the authors of her textbook I can get it for you.
It IS a very bad exemple though. An 18m high King Kong that weights 78kg? Come on.
That's awesome. This is a good reminder that if you're trying to model some real world phenomena it's a good idea to do a sanity check on your proposed answer. If you end up predicting such a cream puff King Kong (how could this guy possibly go toe to toe with godzilla or with Fay Wray for that matter) then you might want to question the method used, especially if you've included it as a solution in a textbook.
A spherical balloon is partially blown up and its surface area is measured. More air is then added, increasing the volume of the balloon. If the surface area of the balloon expands by a factor of 9.4 during this procedure, by what factor does the radius of the balloon change?
If the radius of a sphere is increased by 12 %, by what factor does its surface area increase?
- By what percentage does its surface area increase?
- By what factor does the sphere's volume increase?
- By what percentage does the sphere's volume increase?
The weight of an object at the surface of a planet is proportional to the planet's mass and inversely proportional to the square of the radius of the planet. Jupiter's radius is 11 times Earth's and its mass is 320 times Earth's. An apple weighs 1.0 N on Earth. How much would it weigh on Jupiter?
I am sorry to resurrect this year old thread, but I am having trouble sanity-checking
I am developing an algorithm for assuring children that even if a 12 ft high spider did exist, it couldn't hurt you because it couldn't move.
Here is what I got stuck on:
The chart is based upon 72" high average person (index=me)
h=Height k=new height w=weight y=h^3 w/y (expressed as a percent) = .0509
h in inches...36...66...72...120...1200
h^3... 46656...287496..373248...1728000...17280000
w...23.75...146...190...880...879629
Using either my indexing model or
using the useful formula ((k/h)^3)*w from @HallsOfIvy above...
this model doesn't sanity-check. a 3' tall kid doesn't weigh 24 pounds
I guess I can get a very specific weight for a
100' tall exact copy of 'me'
Sigh! Once upon a time I was 66 inches high and weighed 146 pounds. Now I am 66 inches tall but much more than 146 pounds!
According to this chart,
http://pediatrics.about.com/cs/growthcharts2/l/blboysbirth.htm
a 36" child might be anywhere from 25 to 75 pounds with the average a little below 50. Of course, children are not just "miniaturized" adults- they tend to be stockier and heavier for their height.
When talking about the ability to move, you should include in that that strength is proportional to length squared (because it depends on the cross section area of muscle fiber). A spider, blown up in length by a factor of 10 would be 100 times stronger but 1000 times heavier- so only 1/10 as able to support its own weight.
Ugh, what a terrible problem. Really, you'd expect weight to scale as the cube of height (or, at least, with an exponent between 2 and 3). 2*(1800/46)^3 would be more realistic... unless you think I weigh as much as King Kong.
When I left WV I was 72" high and 135 pounds. I have grown in cross-section
Thanks for the link, and the suggestion. I will post a link to the finished python code. *if it is ever finished...
Yes, that was said in response #6, four and a half years ago! :smile:
:smile:
  • · Replies 25 ·
  • · Replies 43 ·
  • · Replies 20 ·
  • · Replies 24 ·
15K
  • · Replies 28 ·
10K
