What Are the Correct Calculations for Reactance in a Parallel RLC Circuit?
The correct calculations for reactance in a parallel RLC circuit with a 500-ohm resistor, a 0.01 microfarad capacitor, and a 0.5 mH inductor at a frequency of 50 kHz are crucial for accurate circuit analysis. The capacitive reactance (Xc) should be calculated as Xc = 1/(2π * 50,000 * 0.01 * 10^-6), resulting in 318.3 ohms. The inductive reactance (Xl) is calculated as Xl = 2π * 50,000 * 0.5 * 10^-3, yielding 157.1 ohms. The total reactance is determined by subtracting Xc from Xl.
  • Understanding of parallel RLC circuits
  • Familiarity with reactance calculations
  • Knowledge of frequency units (Hertz vs. kilohertz)
  • Proficiency in using formulas for capacitive and inductive reactance
  • Study the derivation of the formulas for capacitive and inductive reactance
  • Learn about impedance in parallel circuits
  • Explore the effects of frequency on reactance
  • Investigate practical applications of RLC circuits in electronics
Electronics students, circuit designers, and anyone involved in analyzing or designing RLC circuits will benefit from this discussion.
DethRose
Hey
im in first year electronics and have a problem with a parallel rlc circuit
im trying to find the reactance (Xc and Xl) for a circuit that has a 500 ohm resister and a .01 microfarad capacitor in parallel with a 500 ohm resistor and a .5 mH inductor. The frequency of the circuit is 50 KhZ
here are my calculations
xc= 1/(2)(pie)(50khz)(.01microfarads)
= 0.32
xl= (2)(pie)(50khz)(.0005H)
=0.157
but i had them both marked wrong...help with this would be very much appreciated
= 0.32
=0.157
You have used the right approach to work out the capacitive reactance and inductive reactance but you have to check your math. You are out by a factor of 1000 in each case.
To find the total reactance you have to subtract the capacitive from the inductive reactance.
AM
Hi there,
Thank you for sharing your question about a parallel RLC circuit. It seems like you have made some good progress in your calculations. However, there are a few things to consider:
1. The units for frequency should be in Hertz (Hz), not kilohertz (kHz). So, the frequency in your calculations should be 50,000 Hz instead of 50 kHz.
2. The formula for capacitance (C) is C = 1/(2πfXc), where f is the frequency in Hz and Xc is the capacitive reactance in ohms. So, your calculation for Xc should be:
Xc = 1/(2π*50,000*0.01*10^-6) = 318.3 ohms
3. Similarly, the formula for inductance (L) is L = Xl/(2πf), where f is the frequency in Hz and Xl is the inductive reactance in ohms. So, your calculation for Xl should be:
Xl = (2π*50,000*0.5*10^-3) = 157.1 ohms
I hope this helps clarify your calculations. Remember to always pay attention to the units and formulas when solving problems in electronics. Good luck with your studies!
10K
