Alternator , generator efficiency
In summary: Hi, I've been looking for an answer to this question - what are the usual efficiency ranges for alternators? Some say 50-60%, but others say as high as 75%. Does the efficiency increase with size?In summary, the efficiency of an alternator generally increases with size. Power station generators typically have higher efficiencies than car alternators.
Mr.Bomzh
90
Hi I've been looking in google although I can't find a definitive answer, what are the usual efficiency range for alternators, some talk about brushed ones in the range of 50 to 60 % , brushelss some say go as highas 75%, maybe some of you folks know from your experience what are the typical efficiency of a power station generator for example, does the efficiency increase with size?
It does increase with size and power stations run on the order of 95%.
You may want to read this thread https://www.physicsforums.com/showthread.php?t=738434&page=4
It doesn't give the complete answer, but discuss about generator efficiency. Generators are never high efficient machines.
I believe you'll find power plant alternators can beat 98%.
They do tricks like use compressed hydrogen for cooling because hydrogen being less dense than air takes less power to pump .
Utility would prefer to sell that energy as electricity than dump it as heat.
Here's a Toshiba link offering 99%.
http://www3.toshiba.co.jp/power/english/thermal/products/generators/hydrogen.htm
In a car alternator the only incentive for efficiency is there's less heat to get rid of, so efficiency let's you reduce heat transfer area which means a more compact unit.
With today's smaller engines and fuel economy mandates there's probably increased attention to efficiency - but in my day everybody had 400 cubic inches and a half acre engine compartment..
http://www.moparmusclemagazine.com/...rysler_300d_well_traveled_brute/photo_01.html
I can provide some information on the efficiency of alternators and generators. Generally, the efficiency of an alternator or generator refers to the ratio of the electrical output power to the mechanical input power. This can vary depending on the type of alternator or generator and its size.
In the case of brushed alternators, which use brushes to transfer current to the rotating armature, the efficiency can range from 50 to 60%. This is because the brushes create friction and can cause energy loss. On the other hand, brushless alternators, which use electronic components for current transfer, can have efficiencies as high as 75%.
The efficiency of a generator or alternator can also depend on its size. Generally, larger generators tend to have higher efficiencies due to their improved design and construction. This is because larger generators have more space for insulation and better cooling systems, which can reduce energy loss and improve efficiency.
When it comes to power station generators, the efficiency can vary depending on the type of fuel used and the type of generator. For example, gas turbines and diesel generators can have efficiencies ranging from 35 to 40%, while steam turbines can have efficiencies of up to 60%.
In summary, the efficiency of alternators and generators can vary depending on their design, size, and type. However, larger generators tend to have higher efficiencies, and brushless alternators can have higher efficiencies compared to brushed alternators. It is also important to consider the type of fuel and generator used when discussing efficiency.
1. What is the difference between an alternator and a generator?
An alternator is a type of electrical generator that converts mechanical energy into alternating current (AC) electricity. A generator, on the other hand, can refer to any device that converts mechanical energy into electricity, including both AC and direct current (DC) generators.
2. What factors affect the efficiency of an alternator or generator?
The efficiency of an alternator or generator can be affected by various factors, including the design and materials used, the speed and load of the rotating components, and the quality of the electrical connections and components used.
3. How is the efficiency of an alternator or generator measured?
The efficiency of an alternator or generator is typically measured by the ratio of output power to input power. This is expressed as a percentage, with higher percentages indicating a more efficient device.
4. What is the typical efficiency of an alternator or generator?
The efficiency of alternators and generators can vary greatly, depending on their design and intended use. In general, most modern alternators and generators have efficiencies of around 85-90%, but some can reach efficiencies of up to 95%.
5. How can the efficiency of an alternator or generator be improved?
There are several ways to improve the efficiency of an alternator or generator, such as using high-quality materials, optimizing the design for specific applications, and implementing advanced control systems. Regular maintenance and proper use can also help maintain and improve efficiency over time.
  • Electrical Engineering
