Register to reply
Quanta of Light
by God Plays Dice
Tags: frequency, light, photon, quanta, wavelength
Share this thread:
God Plays Dice
#1
Mar8-14, 06:21 PM
P: 14
Trying to understand small increments of light.
From a particle perspective, a photon is the smallest increment, dependent on frequency as E=hf.
From Maxwell's wave perspective, light propagates as a result of the energy passing between the E field and the B field. The rate at which this occurs gives the frequency.
So from a wave perspective, how short can a wave of light be? Less than one wavelength?
If I have a source, a radio transmitter, that emits 10 1/4 lambda of light, and 10 lambda is received/filtered/reflected, can the 1/4 thats left when the filter is removed still propagate?
Phys.Org News Partner Physics news on Phys.org
Step lightly: All-optical transistor triggered by single photon promises advances in quantum applications
The unifying framework of symmetry reveals properties of a broad range of physical systems
What time is it in the universe?
Bill_K
#2
Mar8-14, 06:39 PM
Sci Advisor
Thanks
Bill_K's Avatar
P: 4,160
Quote Quote by God Plays Dice View Post
Think some more about classical E&M before you worry about photons.
Nope, that's not the way an EM wave works. The energy does not pass from E to B and back again. E and B are in phase. At the crest of the wave, E and B are both maximum simultaneously. Ninety degrees later, at the node, they are both zero simultaneously. The energy density is E2 + B2. That means there is plenty of energy at the crest, shared by E and B in equal amounts, and none at all at the node.
A short wave pulse cannot be a pure sine wave. If you cut off a sine wave into a short pulse, the wave will no longer be pure, it will contain high frequencies. Frequencies so high that their wavelength is comparable to the pulse length.
God Plays Dice
#3
Mar8-14, 07:01 PM
P: 14
So if you cut monochromatic laser light off it will change frequency?
God Plays Dice
#4
Mar8-14, 07:11 PM
P: 14
Quanta of Light
Example, an extremely low frequency em wave, 0.1hz, if you take a 2.5 second burst is it not photons present in a 1/4 wavelength of a sinusoidal charge/magnetic field?
God Plays Dice
#5
Mar8-14, 07:12 PM
P: 14
laser light^
God Plays Dice
#6
Mar8-14, 07:17 PM
P: 14
I'm thinking about it in terms of a particle accelerator. If I use the 1/4 lambda above can I aim that at a proton and get it to accelerate due to the charge wave?
Nugatory
#7
Mar8-14, 07:29 PM
Sci Advisor
Thanks
P: 3,755
Yes, just as the shape of water waves will change if you do something to disturb their propagation. This is one of the reasons that Bill_K is advising you to understand classical E&M before you try thinking in terms of photons.
God Plays Dice
#8
Mar8-14, 08:52 PM
P: 14
Alright. So can I read any math that will describe this? the limit of the existence of the wave? The other effect I was interested in is the faraday effect... how sharply/irregularly can I twist a linearly polarised wave and keep it as propagating light?
God Plays Dice
#9
Mar8-14, 08:55 PM
P: 14
Feels like what im looking for are the mechanical properties of the ether?!
TumblingDice
#10
Mar8-14, 09:36 PM
PF Gold
TumblingDice's Avatar
P: 272
Bill_K's reply in post #2 seems intuitive enough:
Try this: Draw a sine wave with one full frequency cycle. Now remove/erase as much of the sine wave as you want to represent a shorter pulse. When you're done erasing, draw/add vertical extension(s) to the curve that remains to connect to the zero 'node' axis. Now do you see why fractions of frequency pulse result as Bill_K described?
TheDemx27
#11
Mar10-14, 06:14 PM
PF Gold
TheDemx27's Avatar
P: 92
If you want to learn more about these disturbances people keep referencing: http://hyperphysics.phy-astr.gsu.edu...th/fft.html#c1
Of course, it depends on what filter you put on the signal, but in my experience* it tends towards a sinc function.
*I have no experience.
Register to reply
Related Discussions
Where do quanta come from Quantum Physics 9
Quanta of the other three forces Quantum Physics 0
Wave/Particle Duality in Light Quanta General Physics 15
Is there a quanta of time? General Physics 15
