Register to reply
Wavelength vs. amplitude
by bobie
Tags: amplitude, wavelength
Share this thread:
bobie
#1
Mar9-14, 03:32 AM
PF Gold
P: 550
Is there a relation between the wavelength and the amplitude of a photon (or particle), or all frequencies have the same amplitude?
If the latter, why the wavelength affects the way a radiation passes through matter or slits?
Thanks.
Phys.Org News Partner Physics news on Phys.org
Physicists unlock nature of high-temperature superconductivity
Serial time-encoded amplified microscopy for ultrafast imaging based on multi-wavelength laser
Measuring the smallest magnets: Physicists measured magnetic interactions between single electrons
PhysicoRaj
#2
Mar9-14, 04:17 AM
PF Gold
PhysicoRaj's Avatar
P: 436
There is no dependance of amplitude on wavelength. And it is not necessary that all frequencies (equivalently wavelengths) must have same amplitudes.
bobie
#3
Mar9-14, 04:35 AM
PF Gold
P: 550
Can you answer the second question, too?
Larry Gopnik
#4
Mar9-14, 05:53 AM
Larry Gopnik's Avatar
P: 7
Indeed, Amplitude is not affected, it is merely a 'loudness' I do believe. (Or so I was taught at about 13, therefore it may be wrong).
As for depending on diffraction, longer wavelengths equal lower frequency. That means the wave has less energy, and therefore diffracts more. This is as it is more deeply effected by its environment. That's why wavelength affects awes going through slits more.
bobie
#5
Mar9-14, 06:15 AM
PF Gold
P: 550
[QUOTE=Larry Gopnik;4683601 it is more deeply effected by its environment. That's why wavelength affects awes going through slits more.[/QUOTE]
Thanks, but if we have a laser beam of polarized,collimated light passing throu a wooden slit, the photons are affected or not according to wavelength?
PhysicoRaj
#6
Mar9-14, 06:15 AM
PF Gold
PhysicoRaj's Avatar
P: 436
Quote Quote by bobie View Post
I suggest these are very informative on that : http://hyperphysics.phy-astr.gsu.edu/hbase/mod3.html
http://resources.yesican-science.ca/...em_matter.html
PhysicoRaj
#7
Mar9-14, 06:24 AM
PF Gold
PhysicoRaj's Avatar
P: 436
Quote Quote by Larry Gopnik View Post
That I think is rather a misconception. The wavelength must be comparable to the slit width to get an effective diffraction.
See these in the wiki:
http://upload.wikimedia.org/wikipedi...thspectrum.gif
http://upload.wikimedia.org/wikipedi...hsprectrum.gif
Nugatory
#8
Mar9-14, 06:41 AM
Sci Advisor
Thanks
P: 3,458
Save yourself some grief and try to forget that you ever heard the word "photon" - you can rediscover it when you get to quantum electrodynamics.
Here you are describing a purely classical wave problem, and even thinking in terms of photons is pretty much guaranteed to confuse you if you can't describe and analyze it in classical terms.
bobie
#9
Mar9-14, 06:50 AM
PF Gold
P: 550
Quote Quote by Nugatory View Post
Do your remark apply also to an electron passing through a slit or a hole?
Also, is there any clue to the amplitude of visible light wave?, or of an electron travelling say, at 10^7 cm/s ?
Larry Gopnik
#10
Mar9-14, 06:54 AM
P: 7
Quote Quote by PhysicoRaj View Post
I do apologise. I was merely attempting a simple answer.
bobie
#11
Mar9-14, 07:05 AM
PF Gold
P: 550
That is exactly the picture that made me start this thread, the width of the slit must be equal to the wavelength, that suggested the amplitude to me. What is the relation between the width and the wavelength?
sophiecentaur
#12
Mar9-14, 07:30 AM
Sci Advisor
PF Gold
sophiecentaur's Avatar
P: 11,923
Amplitude of a 'light wave' (or any other EM wave) is a function of the total number of photons involved and not the energy in an individual photon.
Re your comments about electrons, you would hardly expect to get 'big or small' electrons, would you? So amplitude of an electron beam would have to refer to the number of them or the total energy.
Do not reject Nugatory's remark about photons. If you want to discuss wave phenomena then forget the particular nature of Photons or Electrons. You cannot have both views at the same time.
sophiecentaur
#13
Mar9-14, 07:33 AM
Sci Advisor
PF Gold
P: 11,923
I sometimes wonder whether you actually read anything other than what people write on PF. Wiki and Hyperphysics are full of stuff about diffraction and interference. You can find such a lot of information about the basics of the diffraction of waves. I'm afraid it's very Maths based, but that goes with the territory and it does involve some effort on the part of the reader.
bobie
#14
Mar10-14, 02:25 AM
PF Gold
P: 550
Quote Quote by sophiecentaur View Post
2) Re your comments about electrons, you would hardly expect to get 'big or small' electrons, would you? So amplitude of an electron beam would have to refer to the number of them or the total energy.
What if the number of photons involved is 1?
I was referring to one single EMR light-wave or electron: if light is a wave, can there be a wave (of any kind, EM sound etc) without amplitude? I supposed not.
Probably I was wrong, but if a light wave must have an amplitude, I'm asking: what is it and, is it related to frequency?
2) I was told in another thread that now you have electron pumps that can shoot single electrons. Or, imagine an individual electron shot in a cathotic tube, I supposed both go straight like a bullet, else, we could never move it around with precision and get a TV-picture. Am I right so far?
Now imagine that, knowing the precise trajectory of the electron we put exacly in its path a screen (I said wooden to avoid magnetic or other interference) with a hole of varying diameter. There is certainly a point where it would pass throug the hole.
I do not know if this experiment can be made in practice or if it is just theoretical, my question is:
(whatever the real nature or size , if it is poinlike or a wave, or both) how big must the hole be for the particle to go through? and, would it vary with the speed of the electron?
Thanks for your help
PhysicoRaj
#15
Mar10-14, 02:32 AM
PF Gold
PhysicoRaj's Avatar
P: 436
A photon is not a wave again. The wave is not a photon. They are both two ways of interpreting the same thing. The intensity of light in the wave sense refers to it's amplitude. In the particle sense it refers to the number of photons.
PhysicoRaj
#16
Mar10-14, 02:42 AM
PF Gold
PhysicoRaj's Avatar
P: 436
Are you saying that the width has something to do with amplitude?
Drakkith
#17
Mar10-14, 03:41 AM
Mentor
Drakkith's Avatar
P: 11,575
Classically, the amplitude of an EM wave is a measure of the strength of the electric and magnetic fields. You can imagine this as the amount of voltage and current induced in an antenna that detects the EM wave. A higher amplitude EM wave will cause more voltage and current in the antenna than a lower amplitude EM wave. Amplitude is not related to frequency.
The uncertainty in the position of an electron is very small. Many orders of magnitude smaller than the size of a single pixel on a CRT. So while we don't actually know the exact position of the electron, it turns out we don't need to.
No matter how small you make the hole the electron will always have at least a small probability of passing through. This even applies when there is no hole, since the electron can tunnel through a solid barrier and appear on the other side. The thicker the barrier, the smaller the chance is.
bobie
#18
Mar10-14, 04:48 AM
PF Gold
P: 550
Quote Quote by Drakkith View Post
Thanks, drakkith, did you mean small, or big?
is the material of the barrier relevant?
does conductive material make any difference?
What I am really trying to understand is on what exactly probability is dependent:
suppose we could reach such a precision in adjusting the pump and that we succeed in getting an electron through a hole of, say, 1mm, if we keep shooting do all electrons pass through the hole?
One last question, in water we can concretely measure the amplitude of a wave, is there a physical amplitude in sound waves and light waves, too?
Register to reply
Related Discussions
Wave: amplitude, frequency, wavelength Introductory Physics Homework 4
Why is any wave defined by the wavelength, but not by the amplitude? Classical Physics 4
What is the relationship between Wavelength(λ) and Amplitude? Introductory Physics Homework 3
Wavelength or amplitude < a Planick length? Quantum Physics 16
Wavelength and amplitude. Are they related? General Physics 18
