Register to reply
How much amps can i get?
by alexmath
Tags: amps
Share this thread:
alexmath
#1
Mar9-14, 08:14 AM
P: 31
What's the maximum amps that can i get from an aa battery without damaging it and how fast that should happen? Also if i had 2 aa batteries and i want to get maximum amps, how it is better to connect them (series or paralel) and how much does it take them to discharge? (sorry for my poor english grammar). Thank you!
Phys.Org News Partner Engineering news on Phys.org
DIY glove-based tutor indicates muscle-memory potential
Tricorder XPRIZE: 10 teams advance in global competition to develop consumer-focused diagnostic device
Study shows local seismic isolation and damping methods provide optimal protection for essential computing equipment
Simon Bridge
#2
Mar9-14, 09:40 AM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 12,953
The maximum current you can safely draw depends on the battery - some batteries are engineered to cope with a higher power drain than others. Try reading the label on the battery for useage limitations.
You should be able to use some basic circuit theory to work out the answers to the restof your questions.
Put your battery combination in a simple circuit with a resistance R. Don't forget the internal resistance r for each battery.
Use Ohms' Law and the definition of power.
Compare the differente cases.
The time to drain the battery depends on how the battery is built too - batteries are usually rated in amp-hours, knowing the voltage you can turn that into watt-hours and compare with the power dissipated in the different resistances.
Register to reply
Related Discussions
Op amps Electrical Engineering 4
Op-amps help! Engineering, Comp Sci, & Technology Homework 2
Op Amps Electrical Engineering 8
Op amps Advanced Physics Homework 1
Op amps Electrical Engineering 3
