Mathematical model for water rocket
The discussion focuses on modeling the movement of water rockets using Maple software, specifically addressing the pressure dynamics within a 1.5-liter bottle filled with water and air at 4 atm. The user questions the realism of their calculated ejection time of 0.1 seconds for all water to exit the rocket. Participants highlight that the ejection time is influenced by the opening size; larger openings result in quicker water expulsion, while typical toy water rockets, which have smaller openings, take several seconds to empty.
  • Understanding of fluid dynamics principles
  • Familiarity with Maple software for numerical modeling
  • Knowledge of pressure calculations in physics
  • Experience with experimental water rocket design
  • Research fluid dynamics equations relevant to water rocket propulsion
  • Explore Maple programming techniques for simulating physical systems
  • Investigate the impact of nozzle design on water ejection rates
  • Conduct experiments with toy water rockets to gather empirical data
This discussion is beneficial for physics students, engineers interested in fluid dynamics, hobbyists designing water rockets, and anyone looking to enhance their understanding of pressure effects in propulsion systems.
allistair
I have to write a program in maple that calculates the water rockets movement. For this i first need to model the pressure inside the water bottle and also i have to calculate how long it would take for all the water to be ejected from the water rocket, all off this numericaly because the equation gets quite complex. But I'm uncertain if my values for the pressure and especially the amount of water left in the rocket are realistic. For a 1.5Liter bottle that is half filled with air and half with water under a pressure of 4atm my program says that after 0.1s all the water has left the rocket, which seems very little to me.
So here's my question, has anyone here ever done that experiment? (i don't have the time to put together a rocket myself) And if you have can you tell me if this value is realistic?
The time it takes for all the water to leave will depend on the area of the opening it has to go through to get out of the bottle. If the opening is large, it will take very little time. A pressure difference of a few atmospheres is a lot of pressure. Convert it to Newtons per square cm and you can have several Newtons of force acting on less than a kg of mass if there is no nozzle to constrict the flow. Toy water rockets usually have an opening of a couple of mm at most and lose their water in a few seconds.
  • · Replies 26 ·
  • · Replies 17 ·
  • · Replies 20 ·
12K
  • · Replies 21 ·
