How Do Buffers React to Strong Acids and Bases?
This discussion focuses on the behavior of buffer systems when strong acids or bases are introduced. Buffers, composed of a weak acid and its conjugate base, maintain stable pH levels by reacting with added acids or bases. When a strong acid like HCl is added, the conjugate base in the buffer consumes H+ ions, leading to a decrease in pH. Conversely, the addition of a strong base results in a slight decrease in H+ ion concentration and a corresponding increase in pH. Additionally, discrepancies between experimentally determined Ka values and theoretical values can arise from experimental errors and impurities in reagents.
  • Understanding of buffer systems and their components (weak acids and conjugate bases)
  • Knowledge of pH and H+ ion concentration dynamics
  • Familiarity with titration techniques, specifically involving NH3 and HCl
  • Basic grasp of acid-base equilibrium and Ka values
  • Study the Henderson-Hasselbalch equation for buffer calculations
  • Explore the effects of different weak acids and their conjugate bases on buffer capacity
  • Investigate common sources of error in titration experiments
  • Learn about the impact of impurities on chemical reactions and Ka value determination
Chemistry students, laboratory technicians, and educators seeking to deepen their understanding of buffer systems and acid-base reactions.
dagg3r
Chemistry Buffers Theory !
hi guys need some help with buffers heh
anyways my query is say i have a buffer system, then i add say a strong base or a strong acid, then the ph changes, what's a general statement i can make for these observations regarding the h+ ion concentration and stuff. I know that if i have the buffer, and i add hcl the h+ ions will be consumed by the conjugate base in the buffer and if we add heaps of acid the ph will decrease cos of too much h+ just an opinion anyone care to help me out :)
and anyone also care to give me reasons and differences why ka value experimentally is different to the literally value? when doing a titration of Nh3 against HCl. thanks
any ideas the best i can prob come up with is errors with equipment LOL
Hi there,
A buffer is a solution that helps to maintain a stable pH even when small amounts of acid or base are added. This is due to the presence of a weak acid and its conjugate base in the solution. When a strong acid or base is added, it will react with the weak acid or base in the buffer, preventing a large change in pH.
In terms of the H+ ion concentration, when a strong base is added to a buffer, it will consume some of the H+ ions present in the solution, resulting in a slight decrease in pH. On the other hand, when a strong acid is added, it will react with the conjugate base in the buffer, producing more H+ ions and causing a slight increase in pH. Overall, the buffer system helps to minimize the changes in pH caused by the addition of strong acids or bases.
As for the differences between the experimentally determined Ka value and the theoretical value, there are a few factors that can contribute to this. One reason could be experimental error, such as inaccurate measurements or variations in the reaction conditions. Another factor could be the presence of impurities in the chemicals used, which can affect the reaction and lead to different results. It's also important to note that theoretical values are based on ideal conditions, which may not always be achievable in a laboratory setting.
